Bouncy Suspension
Old Feb 1, 2024 | 03:11 AM
LovemyLexus's Avatar
LovemyLexus
8th Gear
Default Bouncy Suspension
Hi,
I have a Lexus RX 300 SE-L 2004.
I love this car and it is usually like driving a cloud.
I was away for a couple of months, car was stationary. I came back and drove it and it is bouncing all over the place, the slightest bump to the rear and it is like being on a fair ground ride. There was an AFS sensor light on but it has now gone off.
I took it to my local mechanic who has looked after the car for years. He said I need to plug in the diagnostics, but the wait it a month at the Lexus garage.
The rest of the car he serviced and said all fine.
I can hear the compressor kick in in the rear right, it seems louder than before and runs for longer.
Any advice would be so welcome, I feel it may be near the end of its life, but I simply can't bear that just yet.
Many thanks!
Old Feb 1, 2024 | 08:20 PM
XRX's Avatar
XRX
Springs or air suspension? If springs - replace struts...
Old Feb 1, 2024 | 08:24 PM
MattRX's Avatar
MattRX
20-yo air suspension, it’s a miracle it lasted this long. Not worth the hassle or cost to replace with new air suspension probably. I would spray bags with soapy water to locate the leak.
Sachs struts for these ride nicely
Old Feb 2, 2024 | 01:08 AM
Oro's Avatar
Oro
Like Matt said, give a shot at leak detection. We fixed a family Lincoln that did this. Finally discovered the solenoid valves were leaking. Replaced O-rings and back to normal. No huge expense of replacing bags, or converting to conventional.
A serious google search might reveal to you what the common failure points are on this particular air set-up. I am not familiar with it in particular.
Aside, I have actually been to St. Peter Port once in the past. A unique and memorable place.
Old Feb 4, 2024 | 11:06 AM
LovemyLexus
8th Gear
Thank you so much.
It is air suspension.
Sorry excuse the ignorance, how do you detect the leak as suggested?
Oro, it is a great place hey! Unique and special!
Lovely to hear you have visited!
Old Feb 4, 2024 | 03:11 PM
Felix's Avatar
Felix
If its a simple fix, great. A long term fix, is to swap out the air bags for regular springs/struts.
Old Feb 6, 2024 | 09:59 PM
XRX's Avatar
XRX
Originally Posted by LovemyLexus
Thank you so much.
spray the soapy water
Old Feb 9, 2024 | 02:02 AM
LovemyLexus
8th Gear
Thanks guys!!
Old Apr 2, 2024 | 02:52 AM
LovemyLexus
8th Gear
Update!
Lexus back from the mechanic.
Two new airbags, bit pricey but sooooo worth it!
Thrilled to have my car back!
Thanks for your help!
patarklee
May 31, 2024 04:33 PM
Jandos
Dec 23, 2019 10:21 AM
AVnGX
GX - 1st Gen (2003-2009)
36
Sep 17, 2018 11:03 PM
fitch
12
Feb 8, 2017 05:30 PM
Stuno1
IS F (2008-2014)
Feb 15, 2015 09:34 PM
