front RT cv axal carrier engine mount bracket
Old Jan 20, 2024 | 05:00 PM
Euntae123's Avatar
Euntae123
4th Gear
Default front RT cv axal carrier engine mount bracket
DIY Broken front right CV axal so I was replacing it with a new one.
I also need to replace the bracket mounted to the engine. My new cv exal inner side does not go all the way in to the transmission fitting due to possible bent bracket.
anyone can give me suggestions where I can buy one?
2006 RX330 Front Wheel Drive with VIN# starting with 2
Cv drive shaft bearing bracket mounted to the engine Part number 12321-0A050
But lexus dealer no item found in the system
Last edited by Euntae123; Jan 21, 2024 at 02:43 PM. Reason: Can’t find the replacement part or anyone help me buy one
Old Jan 20, 2024 | 05:08 PM
Need to know year and exact model, or post your VIN.
Old Jan 20, 2024 | 05:22 PM
MattRX's Avatar
MattRX
Try the superseded number: 12321-20100
Old Jan 21, 2024 | 09:01 AM
Felix's Avatar
Felix
Wrecking yard on e-bay perhaps.....Yrs ago I had a carrier bearing go out as it was rattling around......on a different vehicle thou....
Old Jan 21, 2024 | 09:18 AM
Euntae123's Avatar
Euntae123
4th Gear
Thank you for your helpful reply. I will definitely try the junk yards nearby!!👍
Old Jan 21, 2024 | 09:26 AM
Euntae123's Avatar
Euntae123
4th Gear
Hi MattRX,
Thanks for the superseded number 12321-20100. Online Lexus parts shows up description as Engine Mount bracket (REAR).
Old Jan 21, 2024 | 09:43 AM
Euntae123's Avatar
Euntae123
4th Gear
Does anyone know if Lexus part number: 12321-20100 FT RT cv axal engine mount bracket be replaced with TOYOTA parts,
if so, it would be very helpful for me it you can reply with the cross reference part number for TOYOTA as a replacement.
Old Jan 21, 2024 | 10:52 AM
That is a Toyota part number, there is no difference if you get it from Toyota or Lexus. Same part, same part number.
ELexis
Sep 10, 2024 03:30 AM
tomr51
Jan 23, 2024 05:29 PM
lserlohn
RX - 1st Gen (1999-2003)
Jul 5, 2016 08:10 AM
ThumperPup
Jan 17, 2016 11:36 AM
Lexozz
Maintenance
Nov 20, 2002 05:42 PM
