Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
rear wiper blade replacement RX400h
Old Jul 28, 2019 | 02:56 PM
TommyTT's Avatar
TommyTT
Default rear wiper blade replacement RX400h
How do I change rear wiper blade on my 2008-
RX400h.
Old Jul 29, 2019 | 09:21 AM
Hobbes22's Avatar
Hobbes22
I use part number 85214-0E010, which is just the rubber insert. About $8. Pop off the cover that hides nut that mounts the arm to the rear window. This allows you to bend the arm up at 90 degrees. The wiper assembly just snaps off the arm. I then move the arm to my bench and replace the old rubber with the new. You can reuse the two thin metal strips that help the rubber wiper maintain its shape. Hopefully that's clearer than mud.
The trick is to remove the nut cover...
Old Jan 9, 2023 | 04:10 AM
TommyTT's Avatar
TommyTT
Default changing rear wiper blade on 2008 RX400h
how do I change the rear wiper blade on 2008 RX400h
Last edited by TommyTT; Jan 9, 2023 at 04:31 AM. Reason: found how on utube-https://www.youtube.com/watch?v=pBybUQYdyO0
Old Jan 9, 2023 | 06:14 PM
bigblack06's Avatar
bigblack06
Basically the back of the wiper there is a plastic piece cover that pops off and once off you can pull the wiper forward to take it off. I can try and take a picture of the exact process tomorrow.
Old Jan 9, 2023 | 10:16 PM
TommyTT's Avatar
TommyTT
Last edited by TommyTT; Today at 05:31 AM. Reason: found how on utube-https://www.youtube.com/watch?v=pBybUQYdyO0
GadgetRick
GX - 1st Gen (2003-2009)
19
Dec 2, 2021 01:43 PM
akfd
GX - 2nd Gen (2010-2023)
Jan 4, 2019 05:10 PM
vus1980
Mar 29, 2015 01:19 AM
jeff618
Hybrid Technology
Jan 25, 2012 12:17 PM
wilnis
Sep 15, 2006 06:47 PM
