Will Swapping U140F Require ECM Flash?
Old Feb 1, 2023 | 11:54 PM
PorchDawg's Avatar
PorchDawg
Default Will Swapping U140F Require ECM Flash?
Have a 2002 RX300 AWD with a transmission failure. Prior to pulling the transmission, checked for codes and found nothing but an old stored "center airbag sensor".
installing a used JDM U140F.
Question is will the ECM relearn the new transmission without issues? Or, will the ECM require service before operating the car?
I've seen yes and no on this subject. My trans failure is due to a planetary gear decamping from the rest of the area. The OE transmission was working one hour, then had an odd noise and sudden cease to function. I knew this was gonna happen as the last trans change had two tiny corners of a gear stuck to the magnet. No other metal and fluid not burnt or contaminated.
Any other thoughts or warnings on this swap are quite welcome. I'm not a Lexus mechanic. Retired rice burner mechanic. Mechanically, no problem, but? I have factory SMs. The engine/cradle assembly is ready to drop. Have if out this weekend.
Thanks
Old Feb 2, 2023 | 07:16 AM
Lexmex's Avatar
Lexmex
No reflash, just install the new one. Been there before...
aachowhan
Jul 18, 2022 06:17 PM
Samz
May 29, 2020 02:06 PM
VolodymyrG
Dec 10, 2012 01:38 PM
sktn77a
Aug 25, 2009 06:23 AM
dragular
Dec 31, 2008 04:23 AM
