Shift lever
Old May 13, 2022 | 10:10 PM
rooster1's Avatar
rooster1
Default Shift lever
My shift lever would not go from park to any gear. I jiggled it and she disengaged. Is this a common problem and is there a fix for this
Old May 14, 2022 | 07:03 AM
salimshah's Avatar
salimshah
25 Year Member
There is a safety interlock that prevents it from shifting out of Park.
Have some one stand behind the RX and press the brake pedal and your assistant should confirm the brake light lighting up. If not then that is preventing the interlock from moving out of park.
Take a flat screwdriver and pop off the rectangular rubber block next to shift lever. Once the block is removed you can reach downed press the interlock pin to release it. [Instructions and picture are in the owners manual].
The safety is there for a reason and please have some one investigate. It can be the brake pedal switch or fuse etc.
Salim
Old May 14, 2022 | 03:32 PM
MattRX's Avatar
MattRX
This is a problem on the 99-03 RX and the 1st gen Toyota Highlander (01-07). There's a "shift module" which is under the shifter and inside is a little solenoid. This can fail/wear out and stick. I got one from the junkyard and it fixed the problem. You can't buy it from Toyota/Lexus without getting the whole shifter, so you might have to buy a whole shifter on eBay or find it at a yard.
Old May 16, 2022 | 10:53 PM
rooster1's Avatar
rooster1
Thx salim and matt- it has only happened once so should i buy that part to keep on hand
Old May 17, 2022 | 10:59 AM
salimshah's Avatar
salimshah
25 Year Member
Do we know for sure what needs replacement?
Is it weak battery, bad brake switch, bad release relay, bad shift cable end connector etc.
No sense in buying unnecessary parts till we know the root cause of the problem.
Salim
PS: I think there are two switches on the brake pedal. Please verify, but for sure the one that lights up the brake lights is the one that releases the interlock relay.
Old May 17, 2022 | 11:06 AM
rooster1's Avatar
rooster1
Default Shift module
I was thinking the shift module. Symptom has not reoccured
GmanSC
Nov 25, 2015 02:57 PM
x10civ
RX - 3rd Gen (2010-2015)
Mar 6, 2012 06:47 PM
ilv1004s
Feb 2, 2010 04:26 PM
