O/D switch ONLY changes engine braking
Old May 4, 2022 | 12:17 PM
Soyjer's Avatar
Soyjer
2nd gear
Default O/D switch ONLY changes engine braking
2003 RX300 AWD with u140f transmission:
I have OBD2 code P0766 (S4 SOLENOID STUCK OFF), and predictably no 4th gear, but what I cannot figure out is why, when I press the O/D button, it does NOT do nothing...instead, it engages/disengages ENGINE BRAKING.
My understanding is that the one-way clutches in the transmission are NOT externally controllable, and yet for some mysterious reason I am able to engage/disengage engine braking using my O/D button. How is this possible?
[As far as the P0766 code, I have verified that the S4 solenoid both ohms out correctly and click tests correctly and that the ECM is applying 12 volts to S4 at the proper speed when the O/D button is "off" (and not when the O/D button is "on"), and so I am assuming that probably the valve body has a clog that is preventing the shift to 4th gear. I have changed the filter and fluid. I can live with that problem, but I am curious why I can control engine braking using my O/D button?].
Update: Someone else had the exact same symptoms, and after a new S4, valve body, and ECU, the problem persisted.
netcbc
RX - 3rd Gen (2010-2015)
Aug 27, 2015 12:57 PM
GS300-2002
Performance
Dec 31, 2009 09:08 AM
Cali_Girl
Jul 29, 2006 02:05 PM
texrexlex
17
Mar 31, 2006 05:40 PM
lexbuble96
GS - 1st Gen (1993-1997)
Aug 24, 2005 08:09 PM
