Overdrive
Old Aug 17, 2005 | 12:27 PM
lexbuble96's Avatar
lexbuble96
Question Overdrive
will it mess up your engine if you drive with the overdrive on all the time.
Old Aug 17, 2005 | 02:21 PM
turbogs300's Avatar
turbogs300
Cool
No! Who told you that?
Old Aug 18, 2005 | 10:27 AM
lexbuble96's Avatar
lexbuble96
Default overdrive
I was just wondering what the Overdrive button is for
Old Aug 18, 2005 | 10:30 AM
lexus4jess's Avatar
lexus4jess
overdrive is good.
Old Aug 18, 2005 | 11:37 AM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Without overdrive you wouldnt be able to go over 60mph and your rpm's would be over 5k..
Old Aug 24, 2005 | 12:09 PM
curiousg's Avatar
curiousg
You can go over 60. You will just be running at higher rpm (no such thing as rpm's) - it is basically preventing you from shifting into 4th (the overdrive gear). The only reasons to turn it off are for keeping the engine running hihger for passing power or in a hilly area where you want to prevent it from shifting back and forth. Also useful for towing sometimes - but not sure if anyone uses their GS for towing!
Old Aug 24, 2005 | 08:09 PM
Eric-RPS13-'s Avatar
Eric-RPS13-
start at 50mph with OD on go up to 70
start at 50mph with OD off go up to 70
then
start at 50mph with it off, turn it on at about 65-70 and it excellerates faster with lower revs. (I think the OD in the GS is more then just a "4th gear" because in 2nd and 3rd revs have changed when I hit it from off to on) more then one gear can be overdriven
and our car is listed as a 4 speed with o/d.
*shrugs*
pkpgs
Jul 24, 2013 10:30 AM
flipflop
Jul 25, 2012 04:09 AM
kl323
Apr 4, 2011 12:05 PM
AzNRR_12
Performance
Sep 2, 2002 01:39 PM
JaxFL
Mar 28, 2002 11:05 AM
