VVT Failure?
Old Jun 25, 2018 | 04:42 AM
Drcoffee's Avatar
Drcoffee
This sounds more serious than what people posted above. You accelerated enough to kick down a gear and redlined or close to it, and smoke came out the tailpipe? Now it shudders. I'll put money on a broken piston. There should never be smoke coming out the tailpipe and shudder under accel is a catastrophic failure. The blinking engine light under load is bad. I wouldnt spend too much on fixing this rx.
Old Jun 25, 2018 | 10:20 AM
colenzae's Avatar
colenzae
I disagree. Burning oil on a high mileage engine is normal especially at high revs. The shuddering only happened that one time. I have not seen it since. The engine runs fine except at higher revs under load which I have not been able to reproduce. Engine would not run normally with a broken piston. My money is on worn plugs and/or coil packs.
Old Jun 25, 2018 | 10:07 PM
thomas1's Avatar
thomas1
Don't forget that the PCV valve can also effect the oil consumption....
Old Jul 2, 2018 | 01:57 PM
colenzae's Avatar
colenzae
Yes, PCV valve was replaced 12,000 miles ago.....it was original and suprisingly was not blocked and didn't look bad for its age....
Old Jul 9, 2018 | 02:55 PM
colenzae's Avatar
colenzae
So I have not made any repairs to the ignition system since the original problem (see above) as the car has been running fine. I have 70k on my iridium spark plugs and the coil packs are original. So I'm getting on the highway the other day and bring the car up to 4k. The engine sounds fine and accelerates with no hesitation or loss of power, no visible smoke from the tailpipe, but my check engine light flashes. So I am wondering if the CEL only flashes during an engine misfire and if so, how can I diagnose what the problem is. With 70k on my plugs, I would not be surprised if that is the issue and with original coil packs @ 270k, I wouldn't be surprised if that is the issue. Would the computer show a code for a bad coil pack or should I just go ahead and replace the plugs and coil packs?? All comments are appreciated.....
AlaskanLS
Aug 24, 2018 09:27 PM
buckeycat
Jul 10, 2015 10:25 PM
1WILLY1
Feb 14, 2011 04:24 PM
reddgg70
Jan 23, 2007 04:16 PM
ngagrumpy
Performance
Jul 29, 2004 09:14 AM
