Successful engine pull from top
Old Apr 10, 2026 | 06:13 AM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by Ermondw
Any advice or suggestions on changing the rear seal?
Is your question about the procedure or should it be done or not.
I would as the seal is right there and about $50 part and if it leaks requires hours of labor.
Salim
Old Apr 10, 2026 | 09:56 AM
Ermondw's Avatar
Ermondw
9th Gear
I know I should change the rear seal, even though it is not leaking. My question was about the procedure, how to, since I have not changed one on this type of motor before. Thank you for your help.
Old Apr 10, 2026 | 04:59 PM
salimshah's Avatar
salimshah
25 Year Member
Youtube has a few videos.
It is fairly obvious procedure but like any job a simple task can give you headaches. People use pick, seal removal tool or even sheetrock screw.
Access would have been more difficult with the engine in the bay, but since you have it out 2 mins job tops 10.
Salim
PS: Buy OEM form reputable seller.
Old Apr 11, 2026 | 03:43 AM
Ermondw's Avatar
Ermondw
9th Gear
lailaz
Dec 8, 2023 02:13 PM
RJM17
May 27, 2017 06:49 PM
is300prjs
IS - 1st Gen (2001-2005)
Jan 17, 2014 12:32 PM
Jabberwock
Apr 1, 2010 06:40 AM
madmax98
Nov 18, 2007 01:19 PM
