IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Pulling the 2jzge
Old Jan 15, 2014 | 02:28 PM
is300prjs's Avatar
is300prjs
Default Pulling the 2jzge
Does anyone know of a write or DIY thread on any forum that actually shows whats done? Ive been searching for about two weeks and all I've found were two video of the motor coming out. I looking for something that shows the nuts, bold, wires, and etc. Any help is very much appreciated.
Old Jan 17, 2014 | 12:32 PM
neosxe808's Avatar
neosxe808
not that hard, disconnect/pull out the maf/airbox radiator and fans to give yourself more space. A/c lines, p/s lines, and engine harness ( 5 or 6 plugs, depending on year) out of the ecu box. Downpipe, heater hoses, fuel line. I pulled engine and trans together since I did an auto to my swap, so only disconnected the driveshaft. If you only pull engine, drop the trans mount and remove the trans from the engine. 2 engine mounts on each side of the engine, remove hood for easier cherry picker removal.........hope this helps. May have forgot some stuff, but this is the gist of it.....
Volume23
Build Threads
Aug 17, 2018 12:09 PM
blkstealthpaid4
Jul 21, 2015 12:41 PM
funknstein
Jul 4, 2015 11:01 PM
2jzinsider
SC400 / 300 Classifieds
Oct 5, 2012 09:48 AM
beneteau
Apr 12, 2010 09:09 PM
