2002 RX300 Shift-lock override
Old Jan 19, 2018 | 10:07 AM
Jedediah's Avatar
Jedediah
5th Gear
Default 2002 RX300 Shift-lock override
It's becoming routine for me to have to use the shift lock override button to shift from park in to reverse in the mornings. Is this an indication that I need to replace the shifter cable?
Old Jan 19, 2018 | 11:08 AM
salimshah's Avatar
salimshah
25 Year Member
First thing to do would be to ask some one to stand behind and see if the brake lights come one when you press the brake.
The cable parts is to engage the gears, but the issue is with the safety interlock.
If the brake light does not come on, check fuses and the brake switch. [around the brake pedal]
If they come on, then check the release relay ... around the override button.
Salim
Old Apr 29, 2020 | 09:54 PM
Is200tieu's Avatar
Is200tieu
Salim
my override cover for the override button is stuck. Where is the fuse I need to check?
jasone36
Feb 11, 2020 03:58 PM
AngelMom
May 8, 2017 12:37 PM
ceboman
May 19, 2016 11:59 PM
BostonBill
Sep 1, 2010 10:37 PM
racerjim
Jun 23, 2009 05:23 AM
