Rear valve cover.
Old Nov 23, 2017 | 08:38 PM
Moody1's Avatar
Moody1
Default Rear valve cover.
It appears that replacing the rear valve cover on my 99 RX300 with a 3rd gen model is the fix for high oil consumption. I have not had any luck finding one. Any suggestions?
Thanks
Old Nov 24, 2017 | 07:14 AM
Lexmus's Avatar
Lexmus
Are you looking for used? Here are the part numbers of what you need to do the swap
11201-0A060 rear valve cover (3rd gen)
11213-0A010 valve cover gasket
12204-20040 PCV valve
12261-20091 ventilation hose
Old Nov 24, 2017 | 07:28 AM
Lexmus's Avatar
Lexmus
The rear valve cover is a little over $200 from online lexus dealers. Also need the Toyota FIPG 103, or a similar RTV, for the gasket.
Old Nov 24, 2017 | 10:15 AM
Moody1's Avatar
Moody1
Thank you sir. What models use this valve cover?
Old Nov 24, 2017 | 03:45 PM
salimshah's Avatar
salimshah
25 Year Member
Since you have 99 you may need to replumb the PCV.
Salim
Old Nov 26, 2017 | 03:35 AM
Moody1's Avatar
Moody1
What other issues will develop if I don’t fix and continue to use a quart every 200 Miles?
Old Nov 26, 2017 | 05:28 AM
salimshah's Avatar
salimshah
25 Year Member
Before zeroing on to replacing the valve cover, why dont you confirm the problem by adding a catch-can.
Salim
Old Nov 26, 2017 | 05:49 AM
Moody1's Avatar
Moody1
I thought about that but when I removed the intake to replace the knock sensor it was full oil. Oil was actually dripping out of my he upper intake. The PCV valve hose also had an unusual amount of oil in it. This with the numerous post on the forum it seems like a reasonable assumption that the valve cover is the culprit.
Old Nov 26, 2017 | 07:10 AM
salimshah's Avatar
salimshah
25 Year Member
Since you have the evidence, and also conviction that the newer valve cover will fix the problem then why put it off. You are buying quart at a time + the oil in the chamber will reduce the spark plug life, can weaken your cats and so on ... it will end up costing more than taking are of the problem.
Salim
Old Nov 28, 2017 | 05:02 AM
Drcoffee's Avatar
Drcoffee
Check ebay. You want the one used on the RX330 with 4 lobes across the top baffle. The wrong one has only two lobes. $75 used
https://www.ebay.com/itm/31L015-RIGH...5Z1An2&vxp=mtr
Old Dec 8, 2017 | 07:46 AM
Macmasdad's Avatar
Macmasdad
I agree with Drcoffee ebay is the best option. The 3rd Gen cover I swapped onto my kid's 2000 RX was from a 2006 Toyota Sienna 3.3L.
I am amongst the firm believers on this site that the cover swap is the fix. My son has been driving the RX daily since Sept and there has not been any signs of further oil consumption. When my daughter was driving it the year before, on same city route to/from high school, I was constantly topping it off. "Fortunately" the need to replace the damn knock sensors gave me the opportunity to change this rear cover; along with spark plugs, t-stat, clean the vvt filters. Right now at 199K miles, this engine is running like it is brand new. I just hoping that the prior oil consumption doesn't result in future cat issues for the time he continues to drive it. Probably should dump a bottle of Cataclean in the tank for some preventative measures, even though I think it is just snake oil. Best of Luck, I do not think you will regret changing over to a 3rd Gen cover.
Old Dec 10, 2017 | 07:58 AM
2KHarrier's Avatar
2KHarrier
FWIW, Ebay is where I got mine when I did the cover 3 years ago. Part was readily available and the price wasn't too bad. I was able to reuse the same hose on the new PCV valve, it just had to be trimmed slightly...
Here's the thread discussing what I did.
Unfortunately, the photos are all on Photobucket, and are no longer accessible..
https://www.clublexus.com/forums/rx-...at-a-week.html
Old Feb 27, 2021 | 05:01 PM
jamsk8s787's Avatar
jamsk8s787
I am trying to figure out the same if it is the same as the 2002 2003 model with the screw in type pcv.
greenRX300
Jul 13, 2018 01:07 PM
river
May 10, 2016 03:08 PM
trapreo
12
Sep 12, 2015 06:59 PM
Jaden1
Jul 5, 2014 05:55 AM
JAB
Sep 30, 2013 07:37 PM
