Hi all, my RX300 is reaching 200,000 miles. My coolant level is just below the low level, so I was thinking I might as well do something extra if needed.
Does my car need a coolant flush? Or would drain and fill be just fine enough? If I flush the coolant, is it bad for the car?
Personally I'd just top the coolant off for now and keep an eye on it. It will have to be changed when you do the timing belt/water pump service, no sense in paying to change it to only have it changed again in a few thousand miles.
How do I know when to do the water pump service aside from checking wear from the timing belt?
It is so hard to tell the knowledge level of a person who post on the net. For novices I suggest reading Readers digest guide to Automobile maintenance [very old book can be bought for cheap but covers all basics]. Not to offend any one there are self help books * for dummies.
Water pump is generally replaced when it develops a leak. Since the replacement involves taking off the timing belt, most owners do it primitively with Timing belt change. I gambled on my RX and skipped the water pump change at 90K and did it at 180K. I gambled on my SC and water pump leaked at 120k.
Water pumps are cheap compared to the labor required to replace them. When you do a timing belt change you have already paid for the labor so putting a new pump in is just good preventive maintenance. Just make sure you use an OEM pump, not a rebuilt pump.
