Cluster stopped...question
Old Jun 16, 2016 | 08:07 AM
Piece350's Avatar
Piece350
Default Cluster stopped...question
Hi Everyone,
I have a 2000 RX300, I am the second owner. It only has 160km. Today, my speedo stopped working. Tach still works and fuel indicator still works, but acts out, and does not read fuel accurately.
What could this be? Fuse I would assume...
Any insight would be appreciated...
Cheers
Old Jun 16, 2016 | 08:46 AM
Pzindy's Avatar
Pzindy
Do you have an ABS light on? See this thread...
https://www.clublexus.com/forums/rx-...eedometer.html
Old Jun 16, 2016 | 08:58 AM
salimshah's Avatar
salimshah
25 Year Member
What was done recently? Any mechanical/electrical work that could have removed but not reconnected ground wires?
Salim
Old Jun 16, 2016 | 09:02 AM
Piece350's Avatar
Piece350
@Pzindy,
Thank you for the reply! My ABS light came on because one of my caliper bolts fell off and triggered the sensor...it has been on for almost 1 year now. I am having difficulty clearing it to stay off. So there may be a connection between my axle and rings??? Seems complex...
I am going to start with the basics first. Going to scan it with a light tester first, then go from there...My CEL light has also been on for almost 1 year. CEL was caused by air-fuel sensor.
Old Jun 16, 2016 | 09:03 AM
Piece350's Avatar
Piece350
Salim
Nothing was done recently except for an oil change 5000 km ago. Going into my indy shop on Wednesday for another oil change and to get the cluster checked out.
Old Jun 16, 2016 | 09:31 AM
sktn77a's Avatar
sktn77a
Originally Posted by Piece350
My ABS light came on because one of my caliper bolts fell off and triggered the sensor...it has been on for almost 1 year now. I am having difficulty clearing it to stay off. So there may be a connection between my axle and rings??? Seems complex....
I take it you replaced the bolt immediately? Sounds like something wasn't put back together correctly or damaged. That would explain the ABS light. Here is a post from another forum re: the Speedo:
There should be a wheel speed sensor on each wheel. Typically one of them feeds the speedometer and others do other things. You can lose one (or more) of those coils and you can get the symptoms you are seeing. Short of checking the resistance on each coil there really is no other way to see if that might be the problem except getting the codes read by a Lexus/Toyota dealer or a good indy garage. They will have the model specific analyzers which tell them things you can never get from the standard OBDII port at your local Autozone store. Even checking the resistance is often not a clear cut indication since these are Hall effect sensors. If you have one sensor that reads radically different than the others then that is a likely culprit.
Old Jun 16, 2016 | 09:35 AM
Piece350's Avatar
Piece350
Yes, the bolt was replaced right away. I will have my mechanic look at the wheel sensors on Wednesday. However, what is strange is the fact that my fuel indicator is also acting up. It is reading fuel levels incorrectly and fluctuates, which makes me believe that it could also be a fuse.
Old Jun 16, 2016 | 01:13 PM
maxSteel's Avatar
maxSteel
I had the same problem, documented it here:
https://www.clublexus.com/forums/rx-...725-p1730.html
Old Jun 16, 2016 | 04:35 PM
Piece350's Avatar
Piece350
@maxsteel
Yes, I have the same issue that you had. I'm taking her in next Wednesday for oil change and will check speed sensors.
Thank you kindly!
Old Jun 16, 2016 | 09:23 PM
salimshah's Avatar
salimshah
25 Year Member
Piece:
Is it one or two waring lights or the whole cluster has random issues?
Salim
Old Jun 17, 2016 | 05:55 AM
Piece350's Avatar
Piece350
Piece:
Salim
My speedometer does not work at all and my fuel gauge goes from "F" to "E" continuously when I drive. I read MaxSteels thread about his issue and it appears to be identical to mine. Fingers crossed! I also checked the fuses last night and everything seems to be ok.
Old Jun 17, 2016 | 09:52 AM
salimshah's Avatar
salimshah
25 Year Member
Only 2 issues then. That would mean most likely 2 problems
1. Speedo
2. Fuel Gauge
Speedo gets info from wheel rotation.
Fuel gauge gets signal from the fuel level .. in the fuel tank. Make sure you find the right connector and you can disconnect to see one extreme and ground it to see the other extreme on the fuel gauge. Loose connector can give you wild swings. Once the connector to the gauge has been verified by the above check and the connector is making nice contact, then the culprit is the fuel float unit.
Salim
Old Jun 17, 2016 | 12:32 PM
Piece350's Avatar
Piece350
1. Speedo
2. Fuel Gauge
Salim
Thanks for the info Salim. Will pass over the info. To the shop! I will update once I get it fixed.
Old Jun 18, 2016 | 02:53 PM
maxSteel's Avatar
maxSteel
Salim, I know it sounds unlikely, but somehow my fuel gauge went erratic along with the speedometer fail.
I don't know how they can be related but they both returned to normal when I cleared the ABS fail.
Old Jun 18, 2016 | 03:10 PM
salimshah's Avatar
salimshah
25 Year Member
There are whole lot of things I dont know.
Salim
