Trip A
Old Mar 27, 2013 | 04:27 AM
thug9030's Avatar
thug9030
Default Trip A
Hello all I turned on my car and I noticed where it says my car mileage on has changed to some numbers and it says TRIP A what Is that and how do I get it off.
Thanks
Old Mar 27, 2013 | 05:11 AM
bob2200's Avatar
bob2200
There is a fairly tall, thin black plastic rod sticking out of the bottom of the instrument panel that, when you push it, toggles between odometer, trip A mileage, and trip B mileage. If you hold the rod in while on Trip A or Trip B, it resets the mileage for those functions.
Old Mar 27, 2013 | 05:29 AM
thug9030's Avatar
thug9030
Ok thank u so much and will that put my car on the regular car mileage..
Old Mar 27, 2013 | 05:52 AM
hypervish's Avatar
hypervish
You will have to press it twice, through Trip B, and back to Odometer reading.
"”ODO/TRIP” ****
This meter displays the odometer and two trip meters. To change the mode indication, push the ”ODO/TRIP” **** briefly. Each time you push the ****, the mode changes in order from the odometer to trip meter A to trip meter B, then back to the odometer, etc.
The odometer records the total distance the vehicle has been driven. The twin trip meter records two different distances independently.
For example, you can use one meter to calculate the fuel economy and the other to measure the distance on each trip.
To set the A trip meter to zero, display the A meter reading, push the **** and hold it. The same applies for the B trip meter.
The data of trip meters will be cancelled if the electrical power source is disconnected.
^ That's from page 60 of the owner's manual. http://drivers.lexus.com/t3Portal/do.../00rxom/13.pdf
Old Mar 27, 2013 | 02:28 PM
thug9030's Avatar
thug9030
I guess I should start searching around for a manual.. But thank you for the reply I got a little excited because I thought my mileage went back lol.. Just kidding
Old Mar 27, 2013 | 02:40 PM
hypervish's Avatar
hypervish
You can use the manual on the Lexus website at any time. Just go to https://secure.drivers.lexus.com/lex...nual-search.do
If you prefer a paper manual, I believe Lexus can send you one free of charge if you ask them to.
You're welcome.
Old Mar 27, 2013 | 03:03 PM
thug9030's Avatar
thug9030
Sorry to ask again. But I just got off work and I cannot seem to find that lever for the trip a anywhere
Old Mar 27, 2013 | 05:02 PM
Raoul's Avatar
Raoul
It is bottom/center of the plastic cover on your gauges.
It may be obscured by your steering wheel.
Press it and let it go and it will toggle thru Trip-A, Trip-B, and your mileage.
While on Tirp-A or Trip-B hold the button in for a few seconds and it will reset to Zero.
I use this when I fill up the gas tank.
By resetting one of the Trip counters I can easily tell how many miles I get on a tank.
The second trip meter is helpful if the entire trip (many refills) needs to be captured for business or tax reasons.
Also note that just about every modern vehicle have at least one 'trip counter' and most reset buttons are located just where the RX button is located.
My 1990 Jeep has one.
Old Mar 27, 2013 | 05:41 PM
thug9030's Avatar
thug9030
i still dont see anything to pull. lol :-(
Old Mar 27, 2013 | 06:09 PM
Raoul's Avatar
Raoul
PUSH !
It looks like a little stick coming thru the glass.
All you can do is Push it, not turn it, pull on it or slap at it in any way.
Push once to toggle thru the three settings.
Push and hold for several seconds to reset.
And don't feel bad, I got in a truck once that had 29,000 miles on the Trip counter.
How does that counter go 29k without getting reset...accidently?
Obviously the gauge cluster never got wiped clean.
Old Mar 27, 2013 | 07:59 PM
thug9030's Avatar
thug9030
lol i didnt even notice that little stick thing lol thanks to all
Dispin
Nov 2, 2023 07:35 PM
out2wn
Sep 24, 2014 02:50 PM
vartig
RX - 3rd Gen (2010-2015)
May 13, 2014 12:25 PM
Frank1934
May 8, 2013 08:03 AM
Zammer
Dec 17, 2012 05:48 PM
