Check Engine Code Help....
Old Nov 25, 2010 | 03:45 PM
Leines's Avatar
Leines
Default Check Engine Code Help....
Ok guys...so long story short... i bought the lexus off a guy... engine light was on... he cleared it off.. told me if it comes back its the rear sensor and he will fix it... of course the light comes back on the next day.... so now he sends me $100 for the sensor.... go to partsource... get the codes checked..
5 codes.. .two repeat..
P0120, P0441,P0446,P0441,P0446....
Throttle Postion sensor,
And VSV....
Please help me try to fix this.... Ive been told these arent large problems.. but id like to address them as soon as possible..
Cheers
Old Nov 25, 2010 | 06:35 PM
Leines's Avatar
Leines
Part source quoted 82.28 for the Throttle Postion sensor... but they didnt have a part stocked for the VSV issue.... said it could just be a vacuum line...
Any help greatly appreciated...
Cheers
Old Nov 26, 2010 | 06:01 AM
Lexmex's Avatar
Lexmex
Fix the TPS sensor first, because the other codes with P04XX open a bigger can of worms (can range from a gas cap too the charcoal canister (big black box underneath rear of vehicle to a a VSV line on the top of the engine). However, the P0120 is a rare code on these vehicles, so I'd take care of that first.
Old Nov 26, 2010 | 11:14 AM
Leines's Avatar
Leines
Is this something i can do by myself?? are there any tutorials online for doing this repair... i assume its just switching out a sensor???
Cheers
Old Nov 27, 2010 | 05:08 AM
Lexmex's Avatar
Lexmex
The TPS you could do,
See here, https://www.clublexus.com/forums/rx-...on-sensor.html
and
https://www.clublexus.com/forums/rx-...ging-idle.html
Old Nov 27, 2010 | 06:01 AM
Leines's Avatar
Leines
Ive heard about only buying denso replacement sensors... when i look on ebay i seen delphi TPS for about $30....partsource quoted almost $100 and theirs wasnt a denso either,,,
Any suggestions as far as the replacement sensor goes?? only denso... or is delphi ok as well???
Cheers
Old Nov 27, 2010 | 04:40 PM
Leines's Avatar
Leines
Im also having trouble installing my mirror.. the clip broke...and i got the parts from toyota.. its basically these ball bearings.. really small and this half moon black "spring" but its not springy...and i cant quite figure out how it goes together to attach the mirror again...
Thanks for all the help..
Cheers
Old Nov 28, 2010 | 06:01 AM
Lexmex's Avatar
Lexmex
Cheers
Some things you can user aftermarket parts for, but I've found when I'm playing around with the engine and something like the part in question, I stick to the Denso. It's not something that fails often enough for me to even remotely consider a cheaper part. Just my two cents. We've had issues with people putting non-Denso parts in engine components and winding up with issues.
Old Nov 28, 2010 | 06:02 AM
Lexmex's Avatar
Lexmex
Cheers
I have no idea on this one. I have yet to fix my rear view mirror on the door after many years.
Old Nov 28, 2010 | 06:25 AM
Leines's Avatar
Leines
This is the mirror stuck to the windshield.... its some weird clip and bearing set that it attaches with.. but i cant seem to figure out the proper way... like i said.. i got it attached... now i just pray it doesnt fall down....
Ill start to look for a denso sensor..... doesnt seem to be any on ebay... and the one at partssource was an off brand as well.......
Cheers
Old Nov 28, 2010 | 11:36 PM
code58's Avatar
code58
Double post.
Old Nov 28, 2010 | 11:50 PM
code58's Avatar
code58
Cheers
There IS a possibility that Denso isn't the original manufacturer of that part. If you go to a parts site like www.partsgeek.com and look up the part, it will tell you in the listing if it is OEM. They sell a lot of OEM parts but they won't be in TOYOTA boxes, they will be in the box of the OEM manufacturer.
I just checked the site and they show Aisan (that IS the spelling) as the OEM manufacturer and the price is $48.94. I would always try and stick with OEM parts and many of them can be bought outside of the dealership channel. I have dealt with this co. and they were good to deal with. Quick service and cheap shipping.
Old Nov 29, 2010 | 05:38 AM
Leines's Avatar
Leines
Thanks... I have found an OEM in a toyota bag with the correct part number on ebay for $25... just waiting to hear back about the shipping costs... it makes sense that i couldnt find a denso now tho.....lol..
Cheers
Old Nov 29, 2010 | 05:59 AM
Barryst's Avatar
Barryst
The rear view mirrior assembly can be tricky!
I have had 3 windshields replaced, and on one replacement, the tech had to come back the following day to complete the mirrior assembly. I tried to do it but before loosing the little *****, I figured I would let him finish it the next day. I was not happy driving around with the mirrior hanging!
-Do you have anyone that does windshield replacement in your area? They could assemble it for you.
It would probably be cheaper than the dealership.
Old Nov 29, 2010 | 04:19 PM
Leines's Avatar
Leines
Its stayed up so far.. my problem was the part marked "spring" had little to no spring in it..and needed force to even fit into the bracket..
If it falls off.. ill use the second set of parts and get a pro to install it..
Cheers
Seadaddy
Jan 22, 2017 07:27 PM
NickTomsyc
Nov 3, 2015 03:43 PM
jcjr
May 19, 2010 03:00 PM
Cnatman
Aug 2, 2006 02:09 PM
NesTea420
May 28, 2006 05:51 AM
