code po1155 solution
Old May 7, 2010 | 03:44 PM
python1's Avatar
python1
Smile code po1155 solution
check engine light and vsc light. brought to auto zone showed code po1155. they had in stock a bosch sensor, i installed it after trying a denso ( internet shop) which apparently was defective. what was a little aggrivating was i called denso tech services when the denso sensor did not work. they brushed me off and said take it to a lexus dealer-btw lexus wanted $500.00 installed. my final cost $ 189.00, 5 minutes of my simple labor . done, i know you can buy a universal one for $50 but i wanted a quick neat affordable fix. go do it your selfers!! D
Old May 8, 2010 | 06:48 AM
Lexmex's Avatar
Lexmex
Let us know how you fare with the Bosch sensor
Old May 8, 2010 | 02:07 PM
python1's Avatar
python1
after the 1155 fix the lights came on again, the code reader said po171 so i took out the maf sensor, cleaned it a bit and reinstalled so far so good will keep fingers crossed. The worst case scenerio i will get a new maf at auto zone for $95. and be done with it.Bosch sensor holding up so far will repost down the line.
Old May 9, 2010 | 09:37 AM
python1's Avatar
python1
i put a new maf from autozone in and after 5-10 miles the light came on again. po171. i used the reset tool from autozone and drove again 10 minutes. the light came on again po171 with a new maf. I took to autozone and the knowledgeble sales person said to disconnect the negative battery, then give a try, if still problem, they will exchange for another new one.
Old May 9, 2010 | 06:54 PM
Lexmex's Avatar
Lexmex
I'd love to hook up my computer to your vehicle with my diagnostics packages to see what is going on there, that's the first thing I'd do after getting the light again.
I've had some trouble with my A/F sensor readings during the past week, but only because of the extreme heat we've been having in South Florida.
Old May 11, 2010 | 02:44 PM
python1's Avatar
python1
Default random codes
changed maf.reset then a few miles later 171 again,also found loose hose on back of air box. reset. okay far a few miles then light on again this time po136 171 305 and 301 wtf?. people srarting to tell me the computert or a link may be bad? disconeccted the negative cable for 30 seconds, and then reconected. no lights on yet after a few miles. LEX mex should i take it to lexus for computer diagnosis? wgat do you think? thanks
Old May 12, 2010 | 06:26 AM
Lexmex's Avatar
Lexmex
Wait until you get the code again. Some of these things are temporary. I get codes every so often myself, delete them, and won't see the same code for weeks sometimes.
Old May 12, 2010 | 01:51 PM
Nad1370's Avatar
Nad1370
This should shed some solutions to your Lean codes.
https://www.clublexus.com/forums/rx-...172-p0175.html
Old May 12, 2010 | 02:05 PM
python1's Avatar
python1
toay after driving to work nwith no trouble lights, on the way home lights on again po 171.136.300. i read what nad1370 linked, very good but too tech for me to fix, looks like a trip to the dealer for a piece of mind. at least i gave it a good shot at repair but at this point the problem is toying with my lack of tecnical savy, thanks lexmex. will post results.
qwerty04
Jan 29, 2012 11:32 AM
hyhflo
Dec 28, 2008 06:29 PM
Philly RX
Dec 20, 2007 03:07 PM
lockie
Nov 23, 2007 06:31 AM
sibley
Jul 19, 2004 10:24 PM
