Overdrive problem
Old Jun 21, 2004 | 07:36 AM
sibley's Avatar
sibley
Question Overdrive problem
Help! My RX 300 only goes into overdrive about 50% of the time. Runs fine otherwise but has codes P0171 (Bank one too lean), and P03330 (knock sensor bank 2). Pulled EFI fuse and light went out for a few minutes then came back on. Cleaned MAP sensor and light stayed on. Still intermittent overdrive problem. Any suggestions on what to do next?
Old Jul 19, 2004 | 10:24 PM
Lex_0001's Avatar
Lex_0001
You have two problems with engine.
Replace your MAF sensor and this should resolve the P0171 code. A bad knock sensor causes the P0330 code. Replacing the knock sensor this is very labor intensive but will resolve the P0330 code. By driving your car with a bad MAF sensor it caused your knock sensor to work overtime and may have burned it out.
zarulez
Sep 22, 2024 10:06 PM
cbones1979
Oct 13, 2011 06:32 AM
00&02rx300
Jan 27, 2010 06:17 AM
lockie
Nov 23, 2007 06:31 AM
palaka
Sep 3, 2007 06:58 PM
