Conventional oil
Old Sep 29, 2009 | 06:20 AM
lexus114's Avatar
lexus114
Default Conventional oil
Any of you guy`s use a conventional oil,that really seems to perform well in your RX? I.E Pennzoil,Quakerstate etc.I`m getting kind of tired of such expensive oil changes.Plus Mr.RX is getting older now,and I`m not sure just how much longer I`m going to keep it.
Old Sep 29, 2009 | 06:28 AM
v4tuna's Avatar
v4tuna
In my opinion Castrol GTX is a superior oil...for me pennzoil was always a cheap brand
Old Sep 29, 2009 | 06:29 AM
lexus114's Avatar
lexus114
What are you using in yours?
Old Sep 29, 2009 | 06:43 AM
v4tuna's Avatar
v4tuna
Castrol GTX summer Castrol Syntec winter ... it goes down to 30- 40 below zero C and the synthetic always starts
Old Sep 29, 2009 | 06:54 AM
lexus114's Avatar
lexus114
Can you tell a big difference between the two? or is it about the same? I.E power etc.
Old Sep 29, 2009 | 06:57 AM
v4tuna's Avatar
v4tuna
Same for power but i am not a speeder.
Old Sep 29, 2009 | 08:27 AM
lexus114's Avatar
lexus114
I may just go back to Formula Shell,I like SOPUS products.
Old Sep 29, 2009 | 10:32 AM
bob2200's Avatar
bob2200
Wow... -40C = -40F. You must not be in California. Alaska maybe?
Old Sep 29, 2009 | 10:35 AM
salimshah's Avatar
salimshah
25 Year Member
Engines have been running on conventional oil for billions of miles. The key is to replace it regularly.
WithOUT scientific data at hand, I would only recommend to stay with the same make and try not to switch from synthetic to conventional frequently. I would suggest going to mix formulation to ease the shock and back off if you see leaks.
Salim
Last edited by salimshah; Sep 30, 2009 at 07:39 AM. Reason: missed out key word OUT
Old Sep 29, 2009 | 10:59 AM
lexus114's Avatar
lexus114
With scientific data at hand, I would only recommend to stay with the same make and try not to switch from synthetic to conventional frequently. I would suggest going to mix formulation to ease the shock and back off if you see leaks.
Salim
Good advice Salim.
Old Sep 29, 2009 | 12:02 PM
v4tuna's Avatar
v4tuna
I might burn a bit more oil on synthetic due to it sneaking by . Not so worried about leaks.
Why would the improvement in lubricant qualities develop leaks?
Here is the list of myths from Castrol's site http://www.castrol.com/castrol/gener...tentId=7017050
It just flows so much better at -40
Northern Ontario Canada
Old Sep 29, 2009 | 11:52 PM
code58's Avatar
code58
I agree with V4tuna- I have used Castrol for many many years and I personally don't think there's a finer dino oil on the market. Since it is the only Castrol I have used I can't speak for the others, but I have used other brands in the past and I would not use anything but Castrol. My '04 F-150 uses Motorcraft Semi only because I can buy it so cheap at Wally World, but all my past F-150's have used Castrol from new with excellent results.
komobu
Jun 24, 2020 11:33 AM
jonas's RX
Jan 15, 2016 11:43 AM
FRANK!!
Performance
20
Sep 19, 2008 12:27 PM
Boger74
Apr 22, 2008 07:07 PM
sclover
Maintenance
Mar 23, 2008 05:20 PM
