help. problems with remote central locking
Old Aug 29, 2009 | 09:25 PM
Benjamin T's Avatar
Benjamin T
Default help. problems with remote central locking
2000 rx here.
today i was not able to lock/unlock the rx using the key remote. it was working this morning and when i went to unlock it after shopping... nothing. at first i thought it was a dead remote battery but the car still wouldn't take the signal. i have a second master key with also a good battery but it did not work either.
fortunately, i am still able to lock/unlock the car using the key in the door lock.
i thought to try to look for a blown fuse but i couldn't find anything that was labeled "central locking" or similar.
help?
Old Aug 29, 2009 | 10:53 PM
salimshah's Avatar
salimshah
25 Year Member
RX along with other Lexus lines have a remote disable/lockout feature. This is how it works:
If the receiver gets a transmitted signal and the encoding [signature matching the correct transmitter] DOES NOT MATCH, it shuts out the remote. Then you must use the key to lock/unlock the door and then the remote gets re-activated.
This is a safety feature, that prevents some one with a sweeping transmitter to unlock your vehicle.
In summary, if a fellow Lexus owner uses his/her remote key to unlock their RX near your RX, it will shut off the remote receiver of your RX.
Salim
Old Aug 30, 2009 | 07:03 AM
tomstep2's Avatar
tomstep2
Salim is correct. This happens frequently to me (quite a few RX's and other Lexus in my area). I thought for years that it was a battery issue in my remote...
Old Aug 30, 2009 | 08:01 AM
Lexmex's Avatar
Lexmex
That's why I never had the problem in Mexico, never another RX300 nearby when you need it.
Old Aug 30, 2009 | 10:38 AM
Benjamin T's Avatar
Benjamin T
then how do i correct this? i've been locking/unlocking the car manually, but every time i try the remote again nothing happens.
Old Aug 30, 2009 | 10:59 AM
salimshah's Avatar
salimshah
25 Year Member
^ Engaging the key in the door lock should have enabled the remote again.
I assume the red led on the key lights up [if not you need to replace the battery].
At times disconnecting the battery for 20 min or so clears gremlins [you will loose your seat and radio settings].
If that does not work, you may look into reprogramming the remote [I would not jump to this step without trying to clear the gremlins first]. Search will get you the steps to do this.
Salim
Old Aug 30, 2009 | 03:52 PM
Benjamin T's Avatar
Benjamin T
i ended up doing the latter option... disconnecting the battery. it's now working again... thanks!
lexusrxus
RX - 3rd Gen (2010-2015)
164
Nov 7, 2017 06:53 AM
dliugear
GX - 1st Gen (2003-2009)
Dec 12, 2011 10:05 AM
hypervish
12
Jan 15, 2010 11:09 PM
mj23
Dec 18, 2009 08:12 AM
evileagle
Nov 25, 2008 11:16 PM
