Trans. pan
Old Feb 11, 2009 | 07:00 AM
  #31
lexus114's Avatar
lexus114
Originally Posted by carguy07
I get 4.25 every time, does that mean mine is made in hell too?
Hahahaha,It`s you and me brother!!
Old Feb 11, 2009 | 07:03 AM
  #32
lexus114's Avatar
lexus114
Originally Posted by powerslide
My Trans. stick only goes in one way. It has a bend at the tip, and the bent tip part points to your left when you stand at the front while checking. It won`t slide in but in that one same position or the bent tip stops from going in. Is this the same thing for yall? The weird thing is that the fliud level shows different on both sides? I go by the backside with no words. The side that has cold and hot is high on the stick. Hmmmmm
Yep,my dipstick is the same way,As far as the fluid level check,the AWD should take around 4.25 qts. with the differential drain as well.The fwd should take around 3.9 qts. EH,I said dipstick.Ahhhh,hahahahaha.
Ryan
Old Feb 11, 2009 | 07:08 AM
  #33
thomas1's Avatar
thomas1
Yea when you slide the dipstick it must get residue on the bend, on the front side. The one side that is messed up is always stretching, the back side has a defined line level....
Old Feb 11, 2009 | 08:32 AM
  #34
alaskaty's Avatar
alaskaty
Same here. But if you think about it, the lowest solid line of fluid is going to be the actual reading. It doesn't matter what side you use, as long as you read the lowest level that's covered in fluid - one side is probably rubbing against the filler tube.
Old Feb 11, 2009 | 08:35 AM
  #35
alaskaty's Avatar
alaskaty
I drained the trans, drained the x-fer case/diff (the other sump next to the trans) and replaced the oil strainer...mine took 5qts and still is short of the "hot" mark after I reached normal operating temp.
Old Feb 11, 2009 | 10:27 AM
  #36
mikey00's Avatar
mikey00
Mine is always 5 qts. also.
Old Feb 12, 2009 | 06:32 AM
  #37
lexus114's Avatar
lexus114
Hey,I figured out what`s going on.Carguy and I have the normal RX`s,and you guy`s have the un-normal one`s....... Yeah,that`s it!!
Old Feb 12, 2009 | 07:21 AM
  #38
thomas1's Avatar
thomas1
Naw, you too have the eastern United States cars, not normal here on the western United states....My daddy once told me to never live east of the Missouri River, Now I know why......
Old Feb 12, 2009 | 07:29 AM
  #39
lexus114's Avatar
lexus114
Hahahaha.Your daddy was a smart fellor.
dashan
Aug 5, 2011 10:22 PM
sethjon
May 21, 2011 12:19 PM
sethjon
Apr 12, 2011 04:20 PM
RNDRX
Mar 23, 2009 01:39 PM
alaskaty
Feb 21, 2009 08:52 AM
