Need help
Old Dec 24, 2008 | 08:06 PM
zig's Avatar
zig
Default Need help
Hi all I've Toyota Harrier (RHD RX300).I've problem with my braking system.The brake pads is griping.How to repair it??
Old Dec 24, 2008 | 11:09 PM
salimshah's Avatar
salimshah
25 Year Member
Every 2 yrs or so, you should replace the brake fluid. If it has not been done, I would suggest that you do that.
Next is to make sure the clips (where the brake pads and caliper meet) are clean.
The last item to check would be the surface of the brake pads. Successive hard breaking can burn the crud off.
Salim
Old Dec 26, 2008 | 12:08 AM
code58's Avatar
code58
Salim
Salim- There are a lot of people that don't know the problems that that can cure. Thanks for reminding them! Hard to imagine that the surface of the rotor that doesn't look like it has anything on it can actually have brake pad material deposited on it that can cause pulsation (mimic a warped rotor), shuddering and other problems, but it's true. And if that's the problem it's as simple as Salim says, a few hard stops should clean 'em up and can cure the problem. But once you've made those hard stops don't hold the brake on when stopped or you may just redeposit it. Also wise to make sure no one is close behind you or you'll have more problems than you did! LOL
Old Dec 26, 2008 | 08:54 PM
thomas1's Avatar
thomas1
The original post is confusing, does he mean the brake is not releasing? If so he may have either a bad caliper or a flexiable brake line that is swollen inside and not releasing. My friend had that happen on his GMC truck....Had us scratching our heads for awhile....
Old Dec 26, 2008 | 10:52 PM
code58's Avatar
code58
You're right Thomas- think it's a little language barrier. Those are the 1st. things you should look at when a vehicle gets a few years on it.
Old Dec 26, 2008 | 10:54 PM
code58's Avatar
code58
Zig- could you try and explain in a little more detail just what is happening?
Old Dec 26, 2008 | 11:07 PM
code58's Avatar
code58
Salim
Salim- I just went back and reread your post and realized what I responded to wasn't exactly what you said. I discovered on a brake forum a while back something that I wouldn't have believed but it was from a very reliable brake source. They said that brake material is deposited on the rotor and causes the symptoms that I listed. You can't necessarily even see it but it is transfered when the brakes are quite warm and the pedal is held down as at a stop light. The cure is exactly what you said and i have tried it when I have developed a little pulsation (like a little rotor warp) and it actually works. If anyone is interested I'll try and find it and post.
Old Dec 27, 2008 | 07:26 PM
zig's Avatar
zig
Hi all.I wanna connect to my ride (Toyota Harrier RHD RX300 Japanese) Alpine CHA-S634 changer.Please help me on wiring i don't know how to connect.
10lexISR6
RC - 1st Gen (2015-present)
Jun 25, 2018 08:46 PM
reverndlex
14
Nov 11, 2014 04:39 AM
GenEric587
15
Jul 30, 2013 03:26 PM
danny10989
Suspension and Brakes
Sep 5, 2009 11:43 PM
radicalrev
Maintenance
20
May 14, 2008 07:49 PM
