Brake Booster buzzing when braking....
Old Jan 6, 2012 | 08:56 AM
KingNasGS4's Avatar
KingNasGS4
Default Brake Booster buzzing when braking....
What do you guys think? It only happens when I brake while the steering wheel is fully locked to either side.
For example when I go into a parking lot, or going into a gas station and going up the ramp or when im coming out. Basically any situation where I have to fully lock the wheel and press the brakes at the same time.
I hear buzzing and the brake pedal feels like the ABS is kicking in like when you come to a skidding stop in the snow.
I started noticing this when I hit a pot hole badly causing me to bend a rim a while ago.
What could it be? abs sensor?
Old Jan 6, 2012 | 10:24 AM
GS4_Fiend's Avatar
GS4_Fiend
If its a loud buzz, ur abs motor is becoming weak. Time for new one before it fails.
This has been covered many times if you search.
Old Jan 6, 2012 | 01:53 PM
KingNasGS4's Avatar
KingNasGS4
Wasnt sure if it was the abs sensor or not. I searched but nothing fit my symptoms.
I think that there has to be some sort of correlation with me hitting that pothole and the sound after ward . Again me thinking that it could have something to do with the sensitive abs wire
Old Jan 7, 2012 | 08:45 AM
99 GS3's Avatar
99 GS3
If it's only at full lock it may be possible it's a sensor/wire. Kind of odd, do the resitance checks on your sensors, and inspect the lines under the car at full lock. If you've installed coilovers, springs, air etc maybe the lines got moved some and have tension on them at lock.
Otherwise pump your brake pedal 40 times and then check the fluid level to make sure it good.
And aside from that you may be looking at a brake booster assembly like gs4fiend mentions. How many miles does your car have on it?
Old Jan 8, 2012 | 12:02 AM
shurian's Avatar
shurian
Parting out complete GS4 pm me if u need anything
Old Jan 8, 2012 | 06:07 AM
gtmuggs's Avatar
gtmuggs
Do you have the stock floor mats and what color are they?
slikcat
Suspension and Brakes
Aug 29, 2024 08:38 PM
Laza1
Dec 2, 2016 04:52 PM
xbladex00
May 7, 2015 02:10 PM
781rolo
Dec 14, 2013 01:16 PM
81corolla
RX - 1st Gen (1999-2003)
Dec 13, 2009 07:55 AM
