Maint Req Light
Old Dec 16, 2004 | 05:41 AM
04WhiteRX3's Avatar
04WhiteRX3
Default Maint Req Light
Anyone know how to reset this? Thanks.
Old Dec 16, 2004 | 11:14 AM
CK6Speed's Avatar
CK6Speed
I don't know what the pattern is, but you need to stick the key in the ignition and to a certain on/off sequence and push the odometer button. I watched them do it but don't recall the pattern. Hopefully someone knows and can post the proceedure here.
Old Dec 16, 2004 | 11:29 AM
ryca's Avatar
ryca
The exact sequence is in the owner's manual.
Old Dec 16, 2004 | 11:31 AM
jfelbab's Avatar
jfelbab
With the key in the ignition and off press and hold the ODO button and turn the ignition to the on position.
Old Dec 16, 2004 | 11:39 AM
CK6Speed's Avatar
CK6Speed
Damn, I actually read the whole manual but do't recall that. It is good to know
Old Dec 16, 2004 | 12:42 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
https://www.clublexus.com/forums/sho...ght=maint+reqd
Old Dec 15, 2005 | 01:44 PM
drewpdad's Avatar
drewpdad
Default maint req'd light
If you look in your owner's manual there is a section on warning lights. I believe that all you have to do is press the odometer reset button and turn on the ignition key at the same time. Hold the button in until your odometer reading is 00000. This should make the light turn off.
andy595
GX - 1st Gen (2003-2009)
Oct 26, 2011 09:42 AM
Rudy602
Nov 27, 2010 12:27 PM
5H2DA
Jun 22, 2007 05:16 AM
wiredGS400
Jun 12, 2007 01:27 PM
shikbas
Feb 15, 2005 10:47 PM
