Said indicator light
Old Feb 26, 2026 | 08:45 AM
Rbschaefer's Avatar
Rbschaefer
6th Gear
Default Said indicator light
2001 rx-300. After rebuilding and servicing of front suspension, I now get an intermittent flashing of the Skid detector light with the corresponding warning sound. Totally random conditions on dry road surfaces. Any ideas for repair?
Old Feb 26, 2026 | 09:36 AM
salimshah's Avatar
salimshah
25 Year Member
Skid indicator kicks on when the left side wheels are not turning at the same rate and the right side wheels. The computer does allow a range of mismatch [as you make turns] but not beyond.
Check the wheel tone-ring, sensors and the wiring. During suspension work, ideally the sensors need to be removed and stored away. The wires have a high chance of getting pinched and the simplest of all is a bad connection at the connector.
Salim.
Old Mar 1, 2026 | 05:57 AM
Rbschaefer's Avatar
Rbschaefer
6th Gear
Due to my remote location, are there any circuit breakers that I can pull to stop the intermittent dinging of the anti skid system without affecting the normal breaking of the car? Thx
Old Mar 1, 2026 | 10:47 AM
salimshah's Avatar
salimshah
25 Year Member
I don't have a circuit diagram to help you.
Are tire treads good [no actual slip is happening?
Salim
lmyrick2
HS 250h Model (2010-2012)
Feb 23, 2025 09:07 AM
marshmalow
Oct 1, 2015 03:00 PM
snowice
Oct 31, 2005 08:46 PM
