Airbox Mounts?
Old Mar 30, 2023 | 09:24 AM
CB700S's Avatar
CB700S
Default Airbox Mounts?
I recently had to remove the airbox on my 99 RX300 and noticed that it was quite loose on the bracket even when I tightened the bolts down all the way. Looks like the rubber grommets/cushions/mounts have shrunk with age and need to be replaced, but I can't seem to find them in the Lexus parts catalog. The bolts are there, the rubber parts aren't. Anyone have any suggestions or sources for these?
Old Mar 30, 2023 | 10:42 AM
maxSteel's Avatar
maxSteel
I guess you could use rubber grommets
Amazon Amazon
Or you could use some self adhesive foam or rubber strip under the box to cushion it
Is it a problem?
Old Mar 31, 2023 | 07:44 AM
salimshah's Avatar
salimshah
25 Year Member
These rubber mounts are some what special, and can be built with 2 rubber washer [top and bottom, same size] and a middle rubber grommet [thick washer] and a metal pass through [middle portion, you can cut standoff tubes or better still use the one from existing].
Make sure your engine mounts are good and there is no excessive movement of the engine block. These intake mounting are taking up the mechanical movement difference between the engine and the body. The other thing these moutings do is to do sound insulation from the intake to the body. Intake shell acts as a horn and mechanical waves need to be dampened. You have to wonder why did Toyota.Lexus create the shape of the intake with baffles in them.
Salim
Arcturus
Mar 20, 2021 09:12 AM
1997Soarer
Oct 14, 2018 07:06 AM
ikhanbbb
Feb 20, 2014 03:38 PM
Lexus082
Mar 11, 2013 06:25 AM
Lexiss_sc430
Apr 3, 2011 03:27 PM
