Motor Mount Replacement
Old Dec 9, 2018 | 02:15 PM
Arcturus's Avatar
Arcturus
Default Motor Mount Replacement
Hello,
When replacing the motor mounts on a 01-03 LS430 do you replace just the mount (number 1 in the photo) or all the other parts (2,3 and 4) as well?
Thanks
Old Dec 9, 2018 | 03:23 PM
sha4000's Avatar
sha4000
You can just replace the mount unless you see something else is damaged which is unlikely.
Old Dec 9, 2018 | 04:23 PM
Arcturus's Avatar
Arcturus
thanks. Good to know the other parts are usually ok. For everything it’s not cheap.
Old Dec 9, 2018 | 04:27 PM
911LE's Avatar
911LE
New mounts from Autozone include parts 1, 2, and 3. Part 4 is the aluminum bracket that bolts to the engine block. Part 1 is the only wear/breakable piece.
Old Dec 9, 2018 | 07:50 PM
Arcturus's Avatar
Arcturus
Did you try the mounts from Autozone? What brand were they? I heard that a lot of people have had problems with aftermarket. Sometimes aftermarket can be good though.
Old Dec 9, 2018 | 07:57 PM
YODAONE's Avatar
YODAONE
Do not buy Autozone motor mounts:
See:
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/870764-1998-ls400-engine-mount.html
Old Dec 10, 2018 | 01:08 PM
911LE's Avatar
911LE
I bought the Duralast from Autozone based on price and availability. I didn't want to wait for something to be shipped as the car was up on stands and I live in an HOA community. It looked the same as OEM but I can't really tell. Maybe I'll cut open what's left of my old one to see if it really is hydraulic. The link above is about the 1st Gen LS and ours use different parts.
Old Dec 10, 2018 | 03:18 PM
Peacebay's Avatar
Peacebay
Please update us with your findings! So many people have said they’re hydraulic but I’ve yet to see the proof of that
Old Dec 10, 2018 | 09:15 PM
YODAONE's Avatar
YODAONE
Anyone with an old OEM engine mount they can cut in half in answer?
Old Dec 10, 2018 | 11:21 PM
BCT's Avatar
BCT
How do one check/test if the engine mount is bad? Or do you just replace it after so many years/miles?
Old Dec 11, 2018 | 08:06 AM
Mobius1's Avatar
Mobius1
Its usually replaced "as needed". Generally you'll feel errant vibrations when you didn't beforehand. Or certain noises that weren't present before. Eg: a clunk when you start the engine could mean a worn engine mount.
Old Dec 11, 2018 | 12:44 PM
911LE's Avatar
911LE
Ask and you shall receive. Here's where my mount broke. Couldn't tell until I took it off.
The mount is made of 2 outer pieces of metal crimped together and filled with fluid. The fluid is reddish brown and has the viscosity of water.
I cut both sides of the upper metal piece so I could pry it apart.
I then separated the 2 pieces.
There is a metal piece inside that was surrounded by the fluid. There is one port cut into the side.
Here you can see the fluid cavity.
After disassembly I still don't grasp how these are supposed to work. Both ends of the mount are connected externally with metal and solid rubber.
Old Dec 11, 2018 | 03:53 PM
YODAONE's Avatar
YODAONE
The fluid enhances vibration damping significantly over solid rubber aftermarket mounts.
Anyone with an aftermarket mount to cut in half and post images to present difference?
DO NOT buy aftermarket engine mounts.
Old Dec 11, 2018 | 07:15 PM
Peacebay's Avatar
Peacebay
So it’s settled! Thanks so much for taking the time to cut the old mount apart.
Old Dec 11, 2018 | 07:32 PM
Arcturus's Avatar
Arcturus
Thanks for sacrificing a mount to the engine mount gods. Think we all learned something here!
