More Track Day Fun
Old Jun 23, 2019 | 03:16 AM
Gearbangin's Avatar
Gearbangin
Default More Track Day Fun
So this is fourth day at track with the new car. I’ve picked up five seconds over the four days new FTD 2:05. For comparison my track built ISF at 3600lbs full bolt ons on R comps did a 2:00 flat. So a 2:05 stock at 4,040 lbs isn’t too shabby. Lol my buddy’s was also there in his Solar Flare F. His car is a non TVD
Old Jun 23, 2019 | 07:30 AM
Mingofish's Avatar
Mingofish
Fun day!!
curious if you use an AOS and how much oil you catch each session?
Old Jun 23, 2019 | 10:17 AM
Gearbangin's Avatar
Gearbangin
Not yet but mods coming.
Old Jun 23, 2019 | 10:23 AM
Mingofish's Avatar
Mingofish
You’ll want to get aos soon!
my car pukes a ridiculous amount of oil per session on track. Can’t imagine the varnish & carbon build up without that catcher.
Old Jun 23, 2019 | 11:40 AM
vbb's Avatar
vbb
Good lap! That looks like a fun, not overly technical track as well. The mods and some different tires should have you running the same or better than your ISF even without shedding weight. Question though... I thought you were actively selling the car? If so, why mod it?
Old Jun 23, 2019 | 01:20 PM
05RollaXRS's Avatar
05RollaXRS
Great video. Lots left on the table. 2:05 with basically stock and street tires is very impressive. R-compounds alone can shave get to very low 2s. Once you get full bolt-ons and tune (~ 445 whp), R-compounds, you will be under 2:00 pretty easily even without weight reduction.
Old Jun 23, 2019 | 01:38 PM
Gearbangin's Avatar
Gearbangin
Lol well I’ll probably keep it besides got to enjoy it while I have. It. I think tasteful professionally done mods can add value. It’s been my experience with last three cars I sold all for well over kbb.
Old Jun 23, 2019 | 02:33 PM
05RollaXRS's Avatar
05RollaXRS
At 124 mph, I noticed your back straight speed (flying start) was identical in your RCF and your fully track prep'ed ISF?
Old Jun 23, 2019 | 04:09 PM
Gearbangin's Avatar
Gearbangin
I think I hit 130 but I was full bolt ons about 424 wheel and weighing only 3600 lbs. I think I can get few more mph out of rcf I’m spinning rears bad on start after turn 19 down to second gear to front straight and I’m braking a little earlier bc stock brakes. I’m sure they can handle it fine but I was running full race pads, two piece rotors, braided lines and synthetic brake fluid on the old car.
Old Jun 23, 2019 | 07:51 PM
05RollaXRS's Avatar
05RollaXRS
Originally Posted by Gearbangin
I think I hit 130 but I was full bolt ons about 424 wheel and weighing only 3600 lbs. I think I can get few more mph out of rcf I’m spinning rears bad on start after turn 19 down to second gear to front straight and I’m braking a little earlier bc stock brakes. I’m sure they can handle it fine but I was running full race pads, two piece rotors, braided lines and synthetic brake fluid.
Are you thinking about suspension mods, stiffer bushings etc.? Seems like full bolt-ons and racing slick tires alone should shave off a lot.
Old Jun 24, 2019 | 10:55 AM
Gearbangin's Avatar
Gearbangin
K
Old Jun 24, 2019 | 11:32 AM
05RollaXRS's Avatar
05RollaXRS
So your best lap was within 1 second of the best lap of a stock C7 Corvette Stingray? That is very impressive.
Old Jun 24, 2019 | 12:51 PM
Gearbangin's Avatar
Gearbangin
Its a fast car from factory for sure.
Old Jun 24, 2019 | 02:17 PM
konichiwa3's Avatar
konichiwa3
Absolutely, positively, you got to have the RR penske Coilover. That to me is thee most critical mod anyone can do to the RCF. Car dynamics gets improved unbelievably.
Even the street-able coilover with the lower spring rate makes a humongous difference. Car will be wheezing through corners at unbelievable speeds. Your traction off the line will also tremendously improve as the car will be able to quickly and efficiently put down all that power to the road.
I have had a couple of friends who own Porsches drive my car and be blown away how well the car handles. RCF goes from heavy under-steer when on stock suspension to dead on neutral balance with the RR Penske. You can easily dance the car to over-steer at will with the throttle giving you predictable response.
Gearbangin
RC F (2015-present)
33
Dec 23, 2023 12:24 PM
Gearbangin
IS F (2008-2014)
29
Oct 11, 2018 02:02 PM
Gearbangin
IS F (2008-2014)
Oct 29, 2017 03:37 AM
I8ABMR
IS F (2008-2014)
13
Dec 1, 2016 07:13 PM
BulletproofAuto
IS F (2008-2014)
Aug 26, 2009 11:23 AM
