RCF oil change
RCF oil change
Hey guys,
I know I have read the manual but to double check, I got my first oil change at 1,000 miles from Lexus. Should I wait until the car reaches 5,000 to get a oil change or should I get it done earlier, say around 3,000 to flush all the contaminants out. Also, I have been going up to 5,000 rpm without flooring the vehicle, and yesterday was my first time I floored the vehicle when the engine was warmed up for "1/2 a second lol." Is this a problem?
Thanks!
Thanks!
Hey guys,
Thanks!
Thanks!
5k is the first one that you are recommended to have done.
Probably should specify what mode you're in when you're hitting 5k.
I'm assuming you're not in Manual mode either.
As long as they used decent oil, free is almost always worth it.
There shouldn't be any contaminants anymore if you've already changed after 1k.
Nowadays, most manufacturer's will already do a lot of this stuff pre-shipping out to dealership so it's usually negligible in the first place anyways.
As for mode, I meant: Eco, Normal, Sport, Sport+.
But on another note, if you're in paddle shift mode/Manual, can't you decide when to shift up/down to control RPM?
Yep free is better unless they use low grade oil, and hopefully not lol. I can down shift and upshift and I have been driving in sports plus mode since I got the car with 15 miles on it. Hopefully driving in sports plus non aggressively under 3 to 4k rpm below 1000 miles did not hurt the engine
That way they'll take better care of you and since it's an RC-F it's important to them too.
Also it's a really good connect since most of them have been in the industry a while and know a whole lot of other people for aftermarket stuff too.
Just an FYI for the future since it's already past that point:
1. Brembo break-in has an actual procedure they want you to follow for the first day
-"In a safe area, apply brakes moderately from 60mph to 30mph and then drive approximately 1/2 mile to allow the brakes to cool. Repeat this procedure approximately 30 times." Realistically you only have to do it about 3-5 times.
2. For proper engine break-in you don't actually want to maintain the same speed consistently for too long. You definitely want to push it every once in a while so that the piston rings burnish the cylinder walls to decrease blow-by. Once again though this is mostly done in house already so it's not a big deal but for the first 1k you should try to avoid constant speeds and throttle settings.
Try to befriend the head service manager if you plan on going to the dealership moving forward.
Thank you Eun for all the great information
I'm going to do my own oil/service at a friend's garage too.
There's a member here (@DanielTRLK) who posted a ton of great content in this thread.
When you have to decide which oil to use I'd definitely read through the thread and contact him if you have any additional questions.
one2free
RX - 3rd Gen (2010-2015)
21
04-06-11 12:58 AM
Phresh2010
05-28-10 12:32 PM
