RC F Spacers (Merged Threads)
Old Aug 4, 2019 | 07:19 PM
  #106
05RollaXRS's Avatar
05RollaXRS
Originally Posted by tekjunke
I’ve never used spacers before, but finances don’t allow for new wheels this year... I’ve read this whole thread twice and I’m concerned/confused about what spacers are safest. I daily my RCF, zero track use but lots of 130mph sprints on long stretches of empty road. I get that H&R or Eibach are recommended but neither company has an official fitment for the RCF. Also replacing studs seem logical but adds considerable work/expense.
@ 05RollaXRS, can you share the pn# you used?
I got the IS350 one's since the hub bore size at 60.1 inches is identical to that of the RCF. Make sure they are the ones that don't require replacing the stock bolts. See below for the one's I purchased. I installed them myself and just used some anti-seize on the back side of the spacer (make sure carefully not to let any anti seize get to the studs). I have had mine for about 1.5 years and zero issues.
https://www.tdotperformance.ca/eibac...l-spacers.html
Old Aug 4, 2019 | 07:35 PM
  #107
tekjunke's Avatar
tekjunke
Thank you sir!
Old Aug 4, 2019 | 09:46 PM
  #108
konichiwa3's Avatar
konichiwa3
This is the H&R I got. They are 15mm though which I'm quite happy with for the rears.
https://www.amazon.com/gp/product/B07DN5RCJJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07DN5RCJJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Old Feb 26, 2024 | 02:48 PM
  #109
nigel821's Avatar
nigel821
Anyone have pictures of just 10mm front and rear? I ask this because I picked up 15mm spacers via amazon Vine to review and I honestly don't like how much it pops the rear wheel out. I dislike that the tire is then going to kick crap up on the rear bumper quite easily with how much the tire is now exposed. That and I don't like really seeing the "space" in between the wheel and the hub/spacer. Wheel looks too pushed out to me.
I figured 10mm would be a happy medium for me both front and rear. I'd get the ones that require new studs via H&R. I wouldn't run bolt ons since that's another point of failure to me. The ones I currently have are bolt on and it's easy enough to put them on/off to be able to play with the idea of slightly wider stance.
-Nigel
Old Jun 9, 2024 | 09:52 AM
  #110
JCWonder's Avatar
JCWonder
10th Gear
Any of you guys with 20mm spacers on Swift springs have any rubbing in the *rear*?
Old Jun 9, 2024 | 03:49 PM
  #111
05RollaXRS's Avatar
05RollaXRS
Lowering springs typically do cause rubbing with spacers. It is just the nature of lowering springs. They change the suspension geometry and also your suspension travel reduces getting it closer to the bump stops. On stock suspension, I ran 20 mm spacers for 4+ years and even at angled approach when the wheel is tilted up, there was zero rubbing. Never even a hint of it. I even inspected my fender liners to see if it might not have been audible and nothing there. I reduced it down to 15 mm to be on the safe side for long term wear on the wheel hub and bearings.
The stock springs (I can speak for only the TVD rear springs since they are different from the LSD springs) are stiff enough that even under concentrated load on a specific side of the spring, it prevents the outer tires wall from rubbing against the fender liner. However, when you lower the car, it requires more progressive resistance from the springs to avoid rubbing, which is almost impossible since the springs at that point would be too stiff.
Old Jun 10, 2024 | 05:57 AM
  #112
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
Should fit fine
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old Jun 10, 2024 | 10:51 AM
  #113
stvincent's Avatar
stvincent
^What he said
I run 10.5" in the rear with 25 offset lowered on coils. No rubbing issue.
Old Jun 11, 2024 | 10:55 AM
  #114
05RollaXRS's Avatar
05RollaXRS
My downsizing video from 20 mm in the back down to 15 mm.
Rokas
Aug 7, 2018 09:25 AM
DixonPai
Wheels, Tires & Brakes Forum
Feb 5, 2012 06:35 AM
designo
Nov 8, 2010 11:53 AM
_adiO
Mar 9, 2008 09:56 AM
