RC F Spacers (Merged Threads)
Old Jan 27, 2016 | 04:18 AM
  #46
Santanas's Avatar
Santanas
Originally Posted by Zydan
I'm currently selling my after market wheels, and went back to stock while I wait for new wheels. I went ahead and ordered the spacers recommended here and had them put on Saturday.
Guy at the shop said they were not torqueing properly, they bolts kept feeling like that wanted to continue to torque basically. So I went to the shop, drove the car around for a bit, came back and had it re-torqued, and it was better.
Figured I'd test it out this week and check them regularly, well yesterday when driving home I noticed a sound kind of like metal rubbing on metal, I'm guessing it has to be the spacers rubbing on the hub of the rotors or maybe on the wheel.
I manually re-tightened them with the OEM tire iron and felt the same issue the guy talked about, felt like not matter how hard I pulled I could still tighten one of the bolts just a tad more.
OP, have you ran into any issues?
I think I'm going to remove the spacers and send them back Friday and just be tucking till new wheels. OEM wheels did look much nicer with spacers though /sigh
Where are you selling the wheels? Regarding spacers I was very skeptical about installing spacers on the F, reason why I went and bought wheels, and reading this Im convinced that spacers is like playing the safety lottery, some of them do just fine and others just fly off and you just end against a wall or even worse against incoming traffic at 100mph LMAO, I have read soon many stories about spacers going wrong that I would chicken out too and take them off.
Old Jan 27, 2016 | 05:16 AM
  #47
Zydan's Avatar
Zydan
hahah true true
Wheels are being sold in Dallas, TX, but I believe I already have a buyer for them.
If it falls through I'll post them here.
Old Jan 27, 2016 | 05:34 AM
  #48
JT2MA71's Avatar
JT2MA71
My opinion on spacers, if you really have to use/run them, use the ones that require extended studs. H&R makes the DRS series which comes with spacers and required extended wheel studs.
Old Jan 27, 2016 | 11:30 PM
  #49
da mayor's Avatar
da mayor
Yeah, I took mine off today....so I have spacers for sell lol
I hope they did it all by hand and torqued them to spec.
Old Feb 2, 2016 | 05:43 PM
  #50
equalme's Avatar
equalme
Just installed spacers 15mm rear and 25mm front. Dropped on Swift Sport springs, the front rubs every so slightly on big dips going at speed.
Old Feb 2, 2016 | 05:52 PM
  #51
tarponman's Avatar
tarponman
[QUOTE=equalme;9348962]Just installed spacers 15mm rear and 25mm front. Dropped on Swift Sport springs, the front rubs every so slightly on big dips going at speed.[/
Mine is also white and would love to see pics!
Old Feb 3, 2016 | 07:18 AM
  #52
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
Post up some pics, I went with 20mm in the front and 15mm in the rear and it looks nice and flush, does the 25mm make the tire stick out slightly?
Old Feb 8, 2016 | 07:00 PM
  #53
corradoMR2's Avatar
corradoMR2
The pursuit of F
Are the OEM lugs too long with the 15 or 20 mm spacers? Do they need to be cut or replaced?
Old Feb 9, 2016 | 06:17 AM
  #54
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
I didn't need to cut or replace any bolts at all with mine.
Old Feb 9, 2016 | 08:40 AM
  #55
4everkidd's Avatar
4everkidd
I just ordered BLOX spacers. Chinese replica of the Ichiba V2's / Project Kics spacers. Seem to have really good reviews on other forums, with higher grade hardware than most I've seen.
-salt spray / anti fatigue tested
Spacer body 6061-T6 Forged aluminum
Bolts 10.9 grade
http://www.ebay.com/itm/121821593919?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Feb 20, 2016 | 10:46 PM
  #56
LexusRCF15's Avatar
LexusRCF15
Did you order the same blox sport spacers (15mm) for both the front and rear? I see a lot of guys going with the 20's for the front. If you ordered 20's, which were they from EBay? Thx
Old Feb 21, 2016 | 07:50 AM
  #57
NYCRC's Avatar
NYCRC
I picked up the B2autodesign spacers with 15mm in the rear and 20 in the front. No issues so far. I'm lowered on swift springs and so far I haven't experienced any rubbing.
Old Feb 23, 2016 | 06:53 AM
  #58
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
I ordered the ebay ones, 15 in the rear and 20 in the front. perfect fitment.
I'm running the same size spacers and springs as you, and had no rubbing until this past weekend. I was going about 60-65 mph on a street and there was a BIG dip in the road and it rubbed when I hit it, but this is the only time it's happened. If I was going slower I don't think it would have rubbed at all.
Old Feb 23, 2016 | 08:21 AM
  #59
equalme's Avatar
equalme
The blox spacers look nice but I've read customer service is next to nothing.
I went with the eBay spacers that the OP got, 25F and 15R. The 25F definitely rubs occasionally on dips, and a lot more if you're carrying a passenger (I'm lowered on swift sport springs). I just went ahead and ordered the 20mm.
Btw. Check to make sure all the studs are pressed in all the way. I had a slight vibration and found out two of the studs on one of the spacers weren't pressed in all the way causing that wheel to wobble.
Old Feb 23, 2016 | 11:37 AM
  #60
4everkidd's Avatar
4everkidd
The Blox spacers are great quality, I really was impressed.
I wouldn't risk going with anything less as you never know what type of hardware you are going to get.
As long as you don't order during chinese new year (which I did) the customer service and shipping from Blox is damn quick
