Auto Hi beam camera
New here... Just picked up a 2015 RC F base ... My auto headlights are not working.... Can't find the camera to check aim direction... Didn't see anything around the rear mirror ... Shown a bright flashlight around the grill thinking it might trip the hi beam.. Nothing .. Any help appreciated..
I did that .. The hi beam stork is on high and the auto switch is pressed.... The auto switch light shows on the dash... Unless there is a sequence that I'm not doing... Haven't had problems like this before...
The Auto High Beam action is speed dependent. It turns on the High Beams when traveling over 15 mph. High Beams are to insure you are not "overdriving" your lights, low beams shine out far enough for > 15 mph. BTW, the Blind Spot Monitor (which uses different sensors than the Auto High Beam) also have the 15-mph threshold.
