DFC Active Performance Brake Pad Review
https://www.camaro6.com/forums/showthread.php?t=593345
Now run along and enjoy your walmart brake pads.
This is so awesome.
It's on the first post of that thread you discovered. He upgraded to a 1LE SS later on.
"I am looking to get some better brake pads for my 2018 Camaro LS with single piston stock brakes, and the performance options for these brakes are highly limited.
While browsing RockAutoI stumbled upon"
Indeed looked up the caliper and they are single piston.
On top of that he is not even using the active performance pads in question.
I'll let the forum decide from here. I'm not here to change your mind bro but just wanted to posts facts about my review and for some reason you used my thread to air out your insecurities by using insults, wrong information, and generalities with again.....NO experience on the pads whatsoever and ignored other F users and went on another car forum so prove your point...on DIFFERENT PADS and with one with a single piston caliper. Not even apples to apples.
So when 3 F owners view their personal experience with them (2 of them on the track) you dismiss it because it doesn't align with your base belief.
Even the guy you recently posted said the track pad (which this thread is not about but the active performance) "they were surprisingly good" and had to go to a faster track to cook them. Stop cherry picking. If they were bad I'll let people know on this forum just the same. just like when i got the brembos i let people know it wasn't for canyon carving. But the DFCs performed well for me and two other F guys on this forum and it irked you.
I'm just so perplexed why you're so biased.
I assume because people don't know about them, If they were horrible like you say there would be a large amount of negative feedback on them and you'd have a field day. But even the ones you found liked them initially before heading to a faster track....and again not the pads discussed in this thread. Meanwhile two F owners use them on the track...liked them..and it was not enough for you. I guess Camaro owner hold more weight to you.
We can only assume. But you've done plenty of that, Thank you for showing us. They probably use sawdust and cotton *****. They can be made of rice pudding but they perform very well...again as stated by myself from PERSONAL experience and 2 others.
Have fun with your OEM quiet / low dust pads. I'm glad you like them. They did not perform well for me.
if you’ve already shared your opinion and have no new info other than to restate what you’ve already posted then suggest moving along.
