Brake Pad Recommendations
Old Oct 27, 2019 | 09:42 PM
tnilc's Avatar
tnilc
Default Brake Pad Recommendations
As we all know, the stock pads are very dusty.
Anyone running aftermarket pads? Any recommendations for something with good stopping power and low dust? And by low dust, anything lower than the stock pads.
Old Oct 28, 2019 | 06:10 AM
jonmonkey's Avatar
jonmonkey
I used the powerstop setup with their ceramic pads and D/S rotors before switching to a big brake kit. The dust seemed a lot better with the powerstop pads.
Old Oct 28, 2019 | 09:00 AM
Pittsy's Avatar
Pittsy
How do you like the BBK? is it the RR BBK? I eventually want to get it, but dont see a need for it until I go FI.
Old Oct 28, 2019 | 09:12 AM
jonmonkey's Avatar
jonmonkey
I love the look and the stopping power is much better but they are super squeaky and tough to get bed in to fix that.
Old Oct 28, 2019 | 10:36 AM
Pittsy's Avatar
Pittsy
Which BBK did u get?
Old Oct 28, 2019 | 10:51 AM
jonmonkey's Avatar
jonmonkey
It is the RR Racing kit, front and rear.
Old Dec 1, 2019 | 12:55 PM
tnilc's Avatar
tnilc
Any other recommendations for stock brake calipers?
Old Dec 2, 2019 | 01:41 AM
SethP's Avatar
SethP
Akebono pads are famous for low dust, while maintaining grip that should be equivalent to factory.
I dont need new pads yet, but will go Akebono without question when the time comes. As for rotors, no idea. I like the factory ones well enough, but will likely go with slotted and or drilled ones, for looks.
Old Dec 11, 2019 | 01:44 AM
Moisture's Avatar
Moisture
The dusty pads are due to a material which gently "conditions" the brake rotors are you drive. This is the best type of pad material for your car.
"low dust" options tend to result in a lot of brake juddering when you brake either too softly or too aggressively all the time
Old Dec 11, 2019 | 06:10 AM
jonmonkey's Avatar
jonmonkey
Old Dec 11, 2019 | 08:59 AM
Moisture's Avatar
Moisture
How about you read through this thread and see what a guy working in the brake industry for 17 years has to say regarding the matter?
https://www.mazdas247.com/forum/show...-Brake-Upgrade
highly recommend you do so, mainly in an attempt to stop making yourself look idiotic.
thanks.
Old Dec 11, 2019 | 09:23 AM
jonmonkey's Avatar
jonmonkey
thanks.
You obviously don't take well to sarcasm...
Old Dec 11, 2019 | 09:53 AM
Moisture's Avatar
Moisture
Sorry for being rude.
Sarcasm doesn't translate very well over text... or memes....
Old Dec 16, 2019 | 02:49 AM
SethP's Avatar
SethP
I understand that all things are a balance, and the spider chart/trade-offs of performance(s). But also that best is subjective to the desired outcome.
I've ran Akebonos on several cars, and have personally never experienced the brake juddering you described. Also, I found the stopping performance and life of pads and rotors to be sufficient. This is also the experience of countless others as Akebono is one of the most popular pad brands on the market and has significant support across this forum and others.
AusTexLex
Oct 14, 2011 01:34 PM
kilo6_one
Suspension and Brakes
12
Aug 4, 2006 01:05 PM
CoreY2K1
Maintenance
Sep 20, 2003 06:50 AM
indypwr
GS - 1st Gen (1993-1997)
Apr 4, 2003 11:16 PM
