Wiper Arm Removal
Old May 19, 2023 | 05:58 PM
MKenM's Avatar
MKenM
Default Wiper Arm Removal
Can someone please tell me how to remove the passenger side wiper arm?
Old May 20, 2023 | 12:46 PM
MKenM's Avatar
MKenM
Thanks anyway I figured it out.
Old May 22, 2023 | 04:28 PM
Katsumex's Avatar
Katsumex
Just a heads up, if you're taking it out to replace with a replacement. The dealer sells wiper blade refills that are exponentially better than any aftermarket blades
Old May 22, 2023 | 06:12 PM
MKenM's Avatar
MKenM
No, that is not the case. The windshield was replaced and one of the wiper arms was not put back in the same location (off by an inch or so).
Old May 23, 2023 | 02:47 PM
Giangsturh's Avatar
Giangsturh
dumb question, are the wiper blade refills fit for any wiper blades for example rain-x, michellin ?
Old May 23, 2023 | 02:50 PM
Katsumex's Avatar
Katsumex
They are specifically for the lexus ones, I don't think aftermarket ones you can even replace just the rubber blade.
Old May 23, 2023 | 06:19 PM
CharlieRC's Avatar
CharlieRC
The blades and refills are available from Michelin, Bosch, Trico, and others. The arm itself is probably Lexus only.
RainX makes a pretty good blade with a silicon wiper, there on my RC right now. There are mainly 3 grades in most
replacements, low price ones, mid range and you can spend 25-35 bucks per side. I run the mid-range ones myself.
I haven't found the more expensive ones are better or last longer. Also depends on your location. It's hot and sunny
here in the southern USA so most blades don't last long anyway. I change mine about 2-3 times a year, I can't stand
streaks I guess.Each one their own.
Old May 23, 2023 | 07:27 PM
Giangsturh's Avatar
Giangsturh
Thats the funny thing. I live in south texas and i usually get either a michelin XT blades or rain-X latitude hybrid ones. Then couple weeks later, i got a streak on the driver side, but the passenger side is fine. it's been like this for a while. replace the blades, streaks. i may have to check out the lexus blades.
Old May 24, 2023 | 07:09 AM
CharlieRC's Avatar
CharlieRC
Make sure there is not a chip or road debris of some sort, where the blade sits on the bottom of the windshield that is putting the pits into it. Also rubbing alcohol for cleaning them is good and the same product you put on all of your rubber seals is great for longevity of the blade itself.
Old May 24, 2023 | 10:20 AM
Pittsy's Avatar
Pittsy
For anyone else wondering, it's a 12 or 14mm nut and then the wiper arm can be pulled off. They're pressed on so you might need a tool.
Old May 24, 2023 | 09:09 PM
Forewheel's Avatar
Forewheel
Where in S. TX are you? (sorry to thread-jack). I live in Corpus, on the Island.
Old May 25, 2023 | 06:26 AM
Giangsturh's Avatar
Giangsturh
Houston
WolfyLS460
Aug 1, 2021 10:48 AM
GS4001999
Aug 11, 2013 10:12 AM
azndreamx
GS - 1st Gen (1993-1997)
Aug 18, 2011 10:38 AM
BrianJ
Apr 20, 2010 01:09 PM
MrG4Life
Apr 21, 2007 12:11 PM
