Smog Check with a tune
Old Jun 17, 2022 | 06:11 PM
jkonquer's Avatar
jkonquer
Default Smog Check with a tune
Did anyone have issues passing California Smog Check with a RR-Racing tune on their IS? I'm mainly concerned due to the new ECU regulations in Comifornia,
RR-Racing says it shouldn't be an issue but I would like hear a first hand experience. I
My IS350 is stock except for the tune and I just re-flashed it back to stock to drive around for few weeks prior to the Smog Check.
Thanks
Old Jun 18, 2022 | 07:22 AM
Fman2118's Avatar
Fman2118
Thanks
Ca emission checks now (since 2021) incorporate checking vehicle tuning data against a data base of factory tunes for all makes and models. If a cars tuning doesn’t match what’s supposed to be the factory tuning, the car will fail. If you want to pass, you’ll have to restore the factory tuning and reset the emissions monitors prior to testing in order to pass.
Old Jun 18, 2022 | 06:36 PM
jkonquer's Avatar
jkonquer
How would one reset the emission monitor? doesn't that work just by driving? thanks
Old Jun 18, 2022 | 06:42 PM
Fman2118's Avatar
Fman2118
I will make a correction ……
if the tuning has CARB certification, it should pass emissions. As far as the emissions readiness monitors, you are correct. Several drive cycles meeting certain parameters will need to be completed and there must not be any active or pending codes. Most cars can achieve “ready status” by driving normally for a few days.
Old Jun 20, 2022 | 01:33 PM
jkonquer's Avatar
jkonquer
Off Topic, now that I have driven with stock tune for few weeks I do notice the huge difference in throttle response and the mid range. The RR-Racing tune definitely makes a difference.
Old Jun 27, 2022 | 06:18 PM
jkonquer's Avatar
jkonquer
Well it passed Smog.
FYI, 2014 IS350 F-Sport RWD with 29k miles, flashed back to stock tune from a RR-Racing tune and drove for about 2 weeks, and everything else all stock.
Old Jun 27, 2022 | 06:19 PM
Fman2118's Avatar
Fman2118
good to hear. Bet you’re relieved. 😎
Old Jun 27, 2022 | 06:33 PM
jkonquer's Avatar
jkonquer
You know it. I wouldn't know what to do if I didn't pass?! I have heard people needing to buy a new ecu
tnilc
CL of Southern California
Jun 10, 2022 03:26 PM
xknowonex
Maintenance
May 20, 2005 12:58 PM
SCWells72
May 6, 2003 07:59 AM
nolimit94t
General Classifieds
Feb 19, 2003 05:50 PM
