Help with TPMS sensor
Old Feb 28, 2019 | 03:49 AM
TommyThan's Avatar
TommyThan
Angry Help with TPMS sensor
all sensors are bad and i cant afford to replace/repair them. I want the check system light to go away so i can see my range and how much miles i have left for the tank. Is there anyway to check how much miles i have left with the check system on?
Old Apr 30, 2019 | 04:59 AM
NinjaSocks's Avatar
NinjaSocks
You can still check with the check system warning on but whatever category you are on (tank mileage, temp, etc...) will only be visible for a few seconds until the warning indicator returns.
I am looking for a fix to the warning light myself until I get new sensors.
Old May 1, 2019 | 08:08 PM
Zmon's Avatar
Zmon
Old thread, and OP hasn't been here since March, but... https://www.clublexus.com/forums/is-...7-is250-3.html
tl;dr: 13 years and nobody found a way to disable it. Some 2IS models came without TPMS standard, but requires different ECUs (specifically, Korean body ECU which you'll have to live with a few issues if you go that route. Absolutely not worth it due to cost/hassle). Set of new sensors tends to run around 90-120. Refurb 4 pack will run 60ish.
Old May 2, 2019 | 12:06 PM
NinjaSocks's Avatar
NinjaSocks
The refurbished 4 pack price sounds about good. I'll have to get a set swapped in when I change my tires here soon.
EyeKutr
Jun 12, 2019 10:45 AM
JMcDonald
Nov 20, 2010 09:54 AM
SoDiezl350
Wheels, Tires & Brakes Forum
Oct 31, 2009 04:46 PM
jctheplaya
IS F (2008-2014)
Sep 27, 2009 09:32 PM
ByoungWoo
Aug 27, 2008 03:09 PM
