Heat Shield For Short Ram Intake
Old Oct 16, 2018 | 08:16 PM
Dante486's Avatar
Dante486
Default Heat Shield For Short Ram Intake
Hi I’m new here and I had a question about wether I should install a heat shield for an Injen Short Ram Intake? Is this something that is necessary for all short ram Intakes? I have a 2014 Lexus IS 350 and I see that the air filter will sit behind the headlight, away from the engine.
Old Oct 19, 2018 | 12:59 PM
E46CT's Avatar
E46CT
A CAI is bad enough. but you installed a Hot air intake? Honestly i'd return it to stock. don't bother with no heat shields. you are trying to cool something down which shouldn't be hot to begin with.
Old Nov 25, 2018 | 10:56 AM
sunamer's Avatar
sunamer
Why would you even want that intake? Instead of pulling in the coldest possible air from the airstream hitting the car head-on (stock lexus intake pipe+airbox), you would be using hot air from the engine compartment instead. That will easily drop your performance by 7-15%. What benefit would that serve? There is no heat shield that would shield you from the heat of the compartment, as you would be pulling in hot air. That heat shield will not be able to cool that air, as it is not what it was designed to do. It just can't do this by its design. Its purpose is to simply isolate one component from heat soaking another, which is not the case here.
Old Nov 25, 2018 | 04:22 PM
Dante486's Avatar
Dante486
Have you ever installed this intake on a Lexus IS? The intake sits pretty far away from the engine as it’s below the right headlight. My car sounds so much better since installing it and the acceleration has improved. I’ve had no issue with the intake.
Old Nov 28, 2018 | 01:56 PM
TonyN's Avatar
TonyN
yes on the heat shield, also try the thermal reflective stuff of DEI to reflect radiant temps, a decent heat shield will show a decent temp change.
Old Nov 28, 2018 | 02:14 PM
sunamer's Avatar
sunamer
it is pretty hot down there, when the engine runs above idle. The fact that it “sits quite far away” is irrelevant as there isnt much space in there to begin with, and on top of that, the space is enclosed, which means, it is gonna heat up that air in there pretty quickly . And if you did not test your setup, it is kind of pointless to use subjective criteria to determine whether you did lose some power or not. It might sound good, but the sound is usually not an indication of how much power you gain/lose.
Old Nov 28, 2018 | 04:59 PM
TonyN's Avatar
TonyN
With turbo charge cars and the intercooler setup it runs, hot air pre cooler is not as important, the cooler effectiveness is what really matters as that is the air that get used. Yes, having as close to ambient air temp as possible is important but your overstating the importance when it comes to turbo charge cars that has an after cooler.
Old Nov 28, 2018 | 05:05 PM
TonyN's Avatar
TonyN
here is my setup, using rubber weather strip and insulation does make it effective in keeping away the heat and engine bay air, it also retains the cool air induction that the factory system uses.
I must admit, I did it more for thefsound then the performance gains itself, I wanted to hear the induction and actuator sound and did not want to hamper performance. The larger diameter piping did allow more air flow and smooth it out by removing the flex section.
SJLexus
Mar 5, 2019 09:33 PM
egmmbah
Performance
Jan 6, 2015 06:50 AM
tmh43
Sep 14, 2009 03:17 PM
sc400guy
Jul 18, 2005 12:35 AM
KrazeMatik
May 1, 2005 01:00 AM
