IS300 Diff in GS300
Old Jun 30, 2017 | 06:13 PM
TheDuecer's Avatar
TheDuecer
Default IS300 Diff in GS300
I found a IS300 with a diff (B03B) from what I read this is LSD.
Now my question is would it fit in my 98 Toyota Aristo (A01A) Open diff
could this be a direct swap or could the internals of the IS300 diff be swapped over into the A01A?
Old Jul 1, 2017 | 10:52 PM
GS400V8's Avatar
GS400V8
No the IS diff pumpkins can not swap with the GS nor can the LSD/spyder gears interchange. You will need a MKIV supra or a JZ161 Aristo diff or lsd unit. The Aristo with 3.769 LSD is identical to the Supra except for the cooling fins on the pumpkin.
Old Jul 3, 2017 | 10:50 PM
TheDuecer's Avatar
TheDuecer
Would I need to do the TT axels? to fit a Supra TT diff?
and are TRD lsd's really clunky?
Old Jul 3, 2017 | 11:04 PM
GS400V8's Avatar
GS400V8
With the Supra diff you will only need the axles if you buy the manual 6 speed diff. It is shaped slightly to the side, so the axles end up being different lengths.
If you buy the automatic Supra/Aristo diff it is a direct bolt in.
Not sure if the TRD diff is clunky. The torsens in the OEM units are pretty smooth even though you can feel scrubbing if your below 20 and make a fast sharp turn sometimes but I think it is kindof cool. I'm sure all torsen or clutch pack diffs do this. I don't think any LSD diff is uncomfortably clunky unless you call a welded diff an LSD
Old Jul 4, 2017 | 09:01 AM
99 GS3's Avatar
99 GS3
The 1.5way TRD clutch diffs are smooth as butter. No clunking whatsoever, as long as you use the proper oil and proper break-in of the clutchpacks and change the oil after the break-in, it will be good.
Old Jul 5, 2017 | 07:06 PM
sladkix's Avatar
sladkix
Arristi diff no alder than 1997, newer ones didnt come with Torsen/lsd options.
Goochie
GS - 1st Gen (1993-1997)
15
Nov 4, 2024 05:23 AM
Mcon
Feb 12, 2014 06:22 PM
Dew23
Performance
Jan 30, 2012 12:48 AM
Ken'sGS300
Nov 22, 2010 10:58 AM
