Turbo starting to skip, BurgerTuning Intake for IS200t
Old 04-29-17, 01:28 PM
Jkonyan
Jkonyan's Avatar
Default Turbo starting to skip, BurgerTuning Intake for IS200t
For my IS200t I decided to install a burger tuning air intake only to find out that my car's turbo is skipping, and sometimes flat out fails to spool. If you thought about getting this Intake don't, it'll work fine for 1-2 months then it will start giving problems. From my knowledge of intakes they are suppose to last, but no, this intake turned from bright blue, to a dull and ugly pale blue. If I had installed the intake wrong or anything, and now am speaking nonsense, then please correct me because in all honesty the blow off of the turbo was extremely nice. Anyways if anyone knows what I did wrong, or if it's the intake's fault please message me.
Old 04-30-17, 10:59 AM
Jkonyan
Jkonyan's Avatar
Whenever I press the gas the turbo doesn't smoothly spool up like regularly, instead it does a skip, like taking 2 steps forward and 1 step back. Or a better example imagine rapidly pressing the gas every second, it'll rev then drop. Basically that's happening with the turbo.
Old 04-30-17, 11:19 AM
Sheddy
Sheddy's Avatar
Sorry, that means what?
this dude lol
Are you experiencing a fluctuation issue? If so then the vacuum valve need to be changed.
cbus (05-02-17)
Old 04-30-17, 01:08 PM
Jkonyan
Jkonyan's Avatar
I'm pretty sure it's not from the vacuum value or anything, the car only has 4500 miles, but yeah there is fluctuation, and the turbo gage shows it. I already removed and put the stock air intake back on, I'll be cleaning the air intake soon so if it still happens I'll take a video so you can actually hear what's happening.
Old 04-30-17, 02:02 PM
pnoygil
pnoygil's Avatar
Are you reving your car in park? If yes that would be rev limiter... turbo can't make much bost without load on the engine.
Old 04-30-17, 02:30 PM
Sheddy
Sheddy's Avatar
https://www.clublexus.com/forums/per...t-issue-3.html
If the boost gauge is fluctuating then it can be the vacuum.
Old 04-30-17, 02:47 PM
zcon
zcon's Avatar
sheddy def knows the problem.
Sheddy (05-01-17)
Old 04-30-17, 02:59 PM
Jkonyan
Jkonyan's Avatar
Mine is doing that but not as severe, it's a lot less and eventually smooths out, but this helps out, thanks I'll be taking my car to Lexus soon and see if they'll replace it.
Old 05-01-17, 12:32 PM
E46CT
E46CT's Avatar
Received 2,209 Likes on 1,655 Posts
intake has nothing to do with anything. just a coincidence.
unless you got oil on your sensor or something.
as said its likely the valve causing the sputter
so far so good w/ mine. i dont want to screw with the dealer so i hope it doesnt go bad even though its covered.
Old 05-02-17, 06:55 PM
cbus
cbus's Avatar
It's the valve. Uneven/no boost under accel. Been there, got the T shirt.
kigdaza
03-10-21 12:12 AM
mecheng10
Performance & Maintenance
05-06-14 12:32 PM
LSEGHATCH
15
03-20-07 05:29 PM
mooinperu
12-01-03 11:40 AM
Quick Reply: Turbo starting to skip, BurgerTuning Intake for IS200t
