K&N Intake - WOW
Old May 9, 2003 | 05:41 AM
Jackco711's Avatar
Jackco711
hmmm, strange then.....any idea what it can be? I have the intake with ECU.
Old May 10, 2003 | 12:00 AM
Synergy's Avatar
Synergy
Northern California Regional Officer
What kind of ecu is it?
Old May 10, 2003 | 10:04 AM
Maybe you have SRT and not K&N? The SRT whistles like a banshee.
Old May 16, 2003 | 09:02 PM
Jackco711's Avatar
Jackco711
Nope def. K&N. I called thier tech line again, and again they confirmed that this is normal.
Old May 18, 2003 | 02:35 PM
The K&N intake doesn't have an ECU.
Old May 18, 2003 | 09:03 PM
Jackco711's Avatar
Jackco711
No? So then what are those wires and box inside of it coming out and attaching into my cars comp.?
I have no clue????
Jack
Old May 19, 2003 | 09:07 AM
I have no clue????
Jack
I think you're referring to the mass air flow sensor (MAF) that plugs into the intake pipe. That's a stock piece.
Old May 19, 2003 | 05:32 PM
Jackco711's Avatar
Jackco711
Oh, my bad.Good to know though. So then which intake do I have?
Old May 19, 2003 | 06:19 PM
gs400998's Avatar
gs400998
Here are the pictures of FIPK from K & N website for the GS400:
Old May 19, 2003 | 06:21 PM
gs400998's Avatar
gs400998
Originally posted by SCWells72
Is there a measurable performance gain using this intake, or is the real advantage that it finishes the muscular V8 sound started by the exhaust? If there's a performance gain, approximately how much? Scott
Here is a power gain chart from the K & N website:
Old May 19, 2003 | 07:22 PM
JBrady's Avatar
JBrady
The problem I have with that dyno graph is a similar concern I have about the graphs at SRT. Since the factory fuel cutoff occurs at 6300rpm how is it that these charts go to 6400-6500rpm? I asked SRT and they said the tachometer pickup was off but it is also possible that the cars tach is a bit slow and the engines actually get another 100-200rpm actual rpm before cutoff.
Either way, the K&N piece essentially is just a better flowing stock pipe. It uses the same diameter as the stock car (75mm, <3") and therefore the MAF reading is unaffected and no ECU adjustment is necessary. The power increase listed seems reasonable. Now, the SRT pipe is larger in diameter (3.5") and changes the MAF reading and therefore requires an ECU adjustment to prevent lean out. The SRT part has more HP potential and in fact with the ECU makes more power than the K&N part.
This is a decent upgrade though
Old May 19, 2003 | 07:27 PM
SCWells72's Avatar
SCWells72
Thanks for the info! Now for a variation on my other question...will this work on a GS430 or is the intake placement too different? If it won't work on a GS430, does anyone know if K&N is planning to release one for the GS430? I may call them tomorrow to see what they say...
Old May 20, 2003 | 11:47 AM
How can the larger pipe help when the size of the opening into the throttle body doesn't change?
Old May 21, 2003 | 08:20 AM
SCWells72's Avatar
SCWells72
Well, I asked K&N whether a) the GS400 kit would work on the GS430, or b) there was a GS430 kit in the works. Here's what I got in response:
Our kits are application specific and emissions legal so they do not cross over to other years or models. Unfortunately, we do not have any information on the development of a kit for your vehicle at this time. We apologize for the inconvenience and appreciate your interest in our products.
Best Regards,
Martin Jackson
K&N Engineering
Customer Assurance
1455 Citrus Avenue
Riverside, CA 92507
Oh well...
Old May 21, 2003 | 09:30 AM
Guru's Avatar
Guru
How much is street price for one of those puppies? I was waiting for the Blitz SUS intake but I may give the K&N a try. I have a dyno and an S-AFC II on the car so I can run some tests and also see how the fuel chart looks like. Just dynoing the car stock I have around 244 whp and I can tell you that the fuel curve is perfect out of the box. If I tried to take any fuel at at ALL with the S-AFC I would detonate so I'll have to see if the K&N will lean it out to the point where I'll have to add fuel to keep from detonating. It's VERY hard to hear detonation on this car on the street but it's pretty easy to hear on the dyno.
