Another Intake question..
Old Sep 28, 2020 | 12:00 PM
ELexis's Avatar
ELexis
Originally Posted by MikeFig82
It's pretty much the same as the standard intake pipes out there. Joe Z, HPS. ....
Understood,thanks. MikeFig82. Was interested if perhaps a member had installed it and can confirm fitment in 2008 - 2012 model year IS 350.
K&N lists 69-8704TP, for 2013-2019 IS350. No reference of installing in 08-2012 IS 350.
I've since followed up and inquired with K&N for confirmation. The following reply was received;
"Thank you for your email. The correct kit for the 2008 Lexus IS350 3.5L is part number: 69-8701TP https://www.knfilters.com/69-8701tp-...-intake-system It is not recommended to install a kit that is not fit tested for your application"
Somewhat vague reply, which neither confirmed if it would / would not fit 08 - 2012 IS 350. May be it does fit however, K&N did not do any extensive dyno testing to confirm any benefits over the 2008.
Interesting K&N didn't test fit item in the 2008 - 2012 model years, but did include the 2013 model year.
Old Sep 28, 2020 | 12:13 PM
MikeFig82's Avatar
MikeFig82
Originally Posted by ELexis
Understood,thanks. MikeFig82. Was interested if item was installed without any fitment issues in 2008 - 2013 IS 350.
K&N lists 69-8704TP, for 2013-19 IS350. No reference of installing in 08-2012 IS 350.
Odd K&N didn't test fit item in the 2008 - 2012 model years, but did include the 2013 model year.
Regarding this kit from post#14 since it's for the 3rd gen IS. One of the clamps, and silicone sleeve may not work. I encountered this when purchasing my HPS intake kit. The sleeve for the aibox top is 3.125". Which for the 2nd gen IS the diameter is 3.00"
If you have a 350 you could probably reverse them. Meaning put the larger sleeve on the throttle body. Since the 350 has a larger one compared to the 250. AFAIK some members have mentioned that it's difficult trying to put the 3.00" sleeve on.
Edit: The description of the sleeves qty 2 is 3.125" to 3.00". So one side could be used. As for the other you'll need a 3.00" to 3.00". This will ensure it fits correctly on the air box top.
Old Sep 28, 2020 | 12:47 PM
ELexis's Avatar
ELexis
Appreciate you following up and providing the additional information with regard to silicone sleeve sizing information being overlooked as possible difference, thank you! K&N part # 69-8701TP, does state; Hose; 3”ID-3-1/8”x2”L
allst4risf
IS F (2008-2014)
Jan 7, 2013 01:07 PM
ivnnln
Sep 13, 2009 08:10 PM
dotkong
Performance
Oct 16, 2008 09:51 PM
lexbubba300
Performance
Apr 24, 2004 10:18 PM
Drexenol
Performance
Apr 10, 2004 02:23 AM
