IS200t tune
Old Dec 30, 2019 | 12:00 PM
  #4351
tnilc's Avatar
tnilc
Originally Posted by paulmantis
I sent it in on 12/18
damn wth. Guess I’ll email them.
Old Dec 30, 2019 | 06:04 PM
  #4352
vanillatag's Avatar
vanillatag
Originally Posted by tnilc
When did you send your registration info in?
I sent it in on December 26th, received the registry file on the 29th.
Old Dec 30, 2019 | 06:09 PM
  #4353
tnilc's Avatar
tnilc
wow. That really aggravates me because I sent mine out two weeks ago. I wondering if they’re starting from latest to earliest. Smh.
Old Dec 31, 2019 | 01:06 AM
  #4354
milimart's Avatar
milimart
Default No speed limit
OV please add this to your newest version (speed limit remove)
Old Dec 31, 2019 | 06:07 AM
  #4355
Thirst16's Avatar
Thirst16
Originally Posted by NikNikNik
Is OV still developing a new turbo or did they scrap it?
I emailed them about this last week. The open tuning box will be back at some point but they did not mention anything about the turbo. I doubt they scrapped it.
They have probably pushed the project aside for now while they focus on getting the tunes worked out and polished. There are several of us waiting to purchase the tune until they get most of the kinks worked out so I'd imagine that is top priority.
Additionally, RR Racing may be releasing a full tune at some point in 2020. I'm sure they will also work on a turbo upgrade if the demand is there.
Old Jan 1, 2020 | 07:04 PM
  #4356
vanillatag's Avatar
vanillatag
Same. Just sent my ECU information in to them a few minutes ago!
Have you received the tune file yet? (I am still waiting for Mathew to send mine).
Old Jan 2, 2020 | 06:09 AM
  #4357
Minitech's Avatar
Minitech
I was about to email Matt, but i wanted to check and see if anyone else is having this issue on 1.02. When i run 1.02 i get a code of P0505 - Idle Air Control (IAC) System Malfunction, but its only when i run it in hard boost. My car is stock 2016 IS200t f
Old Jan 2, 2020 | 06:47 AM
  #4358
WhyHateTho's Avatar
WhyHateTho
Seems like a common issue on 1.02. I never upgraded, I'm still using 1.01G-C
Old Jan 2, 2020 | 08:58 AM
  #4359
Minitech's Avatar
Minitech
Thanks yeah same here i am on 1.01G-C and no issues on that tune. At least with that feedback, i know Its more common issue and not just my cars IAC with 1.02 setting faults. I usually only flash to 1.02 if i am going on a spirited drive on some back roads for an afternoon, it seems to be worse too when its colder like it is now, when its warmer i don't get the fault triggered as soon and can run it for a few weeks before it sets that fault.
Old Jan 2, 2020 | 10:13 PM
  #4360
milimart's Avatar
milimart
I’m using 1.02 more more than 3 months and got no issues. I drive my IS daily.
Old Jan 2, 2020 | 10:36 PM
  #4361
unameandy's Avatar
unameandy
I using 1.02 version since Sep 17, I drive daily also no any issue.
Old Jan 2, 2020 | 11:21 PM
  #4362
Jomaduh's Avatar
Jomaduh
For all those running 1.02 who had been using 1.01 before, how different is it?
Old Jan 3, 2020 | 09:09 AM
  #4363
1stwrldprb's Avatar
1stwrldprb
The 1.02 tune is/was the strongest tune, but my car would go into limp mode and throw a code for throttle actuator range, so I reverted back to the 1.01 tune for now. Matt asked me to do some data logging but I haven't had the chance to make it back to the track yet to log some 1/4 mile runs.
Old Jan 3, 2020 | 10:02 AM
  #4364
paulmantis's Avatar
paulmantis
Default Just flashed 1.02
It's a completely different car, i'm so stoked. Hoping I don't encounter any issues, thinking it may be prudent to keep my laptop and tuner in the car with me though!
Old Jan 3, 2020 | 01:25 PM
  #4365
Minitech's Avatar
Minitech
Agreed 1.02 is much better for power and torque then 1.01. I love that tunes throttle response too, but for me in the warm months is the only time I can really run 1.02 without setting a fault, also I just keep a cheap code reader and clearer scan tool in my car for when it throws the code. In a pinch, you could use the OV software to read the code and clear it. For cold months like now, I just use 1.01G-C and I have 0 issues with that older tune but is considerably lower on power and torque. I have ordered a HPS intake pipe and K&N air filter but I seriously doubt that it will help with setting a fault on 1.02. Hopefully, OV will address this in their next release. (btw my car is an early build 16 so that might be some of my issues)
