IS200t tune
Old Feb 20, 2017 | 12:58 AM
  #241
Nuke's Avatar
Nuke
Thumbs up
Originally Posted by specONE
Piggy backs are useless (I.e. vrtuned, etc. )
the Toyota ECU is too smart and whatever power gains initially felt will be countered and lost after some time when the ECU relearns itself.
ECU reflash is the way to go. (Up until recently it was un-doable but the gates are open and tuners are out there giving us something real)
Wait for tuners to unlock all potential of of the 200t motor (8AR-FTS) like they have been recently with the 2GR-FE and 2UR-GSE
I do agree with you to some extent, as only an ECU tune would remove the real limitations that are put by the factory
Old Feb 20, 2017 | 01:37 PM
  #242
hambrabi's Avatar
hambrabi
So basically theres no point in buying a piggyback tune?? Does this mean its a huge waste of money? Like if you paid $600 for a piggyback tune, it works great the first week, then Toyota's ECU just overrides it by learning and adapting then re-adjusting back to stock settings....
Tbh, I was going to go for hard mods, I already have a BMS intake, and originally I wanted to get a really good piggyback tune because its plug and play and you can just remove it later so it wont void your warranty. Now I am just just either considering changing to exhausts/cam shaft, but thats already so costly its not worth it (Originally I chose the 2 liter engine due to being hopeful that I can mod it somewhat cheaply/without voiding warranty and better fuel economy). I might as well just return the car at the end of the lease.
Old Feb 20, 2017 | 01:56 PM
  #243
Sheddy's Avatar
Sheddy
I've been running my piggyback for over a month and the wow factor is still there!
Old Feb 20, 2017 | 06:56 PM
  #244
Nuke's Avatar
Nuke
I think specONE is assuming honestly none of us know but from what I know I don't think its all so true, you see the Piggyback is modifying the signal that already left the ECU in other words its between the sensors and the ECU, so matter how smart the ECU is I don't think it has the power to change what comes after signal is sent (Unless that ECU is GOD ), again am only assuming based on logic
Old Feb 21, 2017 | 04:48 AM
  #245
Pacific13's Avatar
Pacific13
This could be true but, you have other numerous informations which go back to the ECU and these informations (temp, rev, torque) could be analysed and compared to the initial order. Thus in case of difference the ECU could be corrected accordingly. I remember on my GT86, that after having replaced the air filter with a HKS, it was necessary to wait few days to obtain the gain expected (3 or 4 ;-) ) It was exactly the same when air pipe was replaced with a MISHIMOTO. The first day only the noise was incease (placebo) it was necessary to wait. For exemple, resset you ECU and you will certainely note a difference of reaction as the Toyota/Lexus ECU keep in memory you driving habit.
The piggy will certainely modify some parameters but in fact I'm not convinced that the gain remain long time. Why although the numerous piggy on the market we do not find any reals DYNO results??
The only way remain a complete flash of the ECU, for example with ECUTECK and in this case it will be possible to have a real result with the tables corrected for the engine et for the gear. .
Today it is not yet possible but wait and see.
For my side I will certainely order a Electronic throttle controller (Tom's or Blitz) to modify the throttle and remove the lag. It not modify the ECU, just change the electric command of the accelerator. I guess it will be usefull in the driving comfort.
Old Feb 21, 2017 | 05:19 AM
  #246
Nuke's Avatar
Nuke
I like your prospective of this, lets wait and see what BMS comes up with, knowing them they wouldn't release something that wont work long term
Old Feb 21, 2017 | 11:35 AM
  #247
specONE's Avatar
specONE
Its been ongoing for years that Toyota/Lexus for years were untune-able due to not being able to be reflashed (until recently) and piggybacks have initial gains but then fall back and relearn itself...
Do a search for VRTUNED (piggyback) on here (CL forums) for the older 2IS model vehicles. There is long discussion about it in the past.
Burger tune maybe different story and maybe they are onto something but judging by past piggyback, I'd hold my breath for now.
Nothing against Burger tune but maybe they know something now that other piggybacks didnt?
I dont have a IS200t but a IS350 instead.
I've been around Lexus's for years now and Piggy back and reflashing tuning was never talked about as worthwhile because it never works and was a waste of money. I'm not into wasting money for placebo effect.
Recently the ECU are now reflashable, and I have put forth money to get my ECU reflashed with a Tune that isn't a waste of money.
I'm just putting my two cents, take it as you wish.
Old Feb 22, 2017 | 06:33 AM
  #248
cbus's Avatar
cbus
Waiting eagerly for a legit reflash tune for my 200t. I already have wide wheels/tires and I'm searching for a 2010+ ISF diff. It would be nice to make even more use of those things.
Old Feb 22, 2017 | 07:43 PM
  #249
Arthur1523's Avatar
Arthur1523
Okay so does this VRTune work or should we just wait for Burgertuning to throw in some magic? Does anyone have maybe an approximate time frame Burgertuning will have it ready for us? I want speed already! Already have my injen intake and a muffler and res delete! Also does anyone know if there are any downpipes and testpipes available?
Old Feb 22, 2017 | 07:53 PM
  #250
Nuke's Avatar
Nuke
Wait in general for more tests to be conducted and more dynos to become public so point is not BMS or any other vendor... point is wait for more real users to do real tests
there are no "Official" down pipe yet but you can find some custom work here if you search in the forum, test pipe is available from few vendors and I personally have the Invidia along with the Q300 Axle back
Old Feb 22, 2017 | 07:56 PM
  #251
Arthur1523's Avatar
Arthur1523
Can you post the link for the testpipes please. Not really looking for a exhaust system so will pass on the axle back. Already muffler and resonator deleted my car. Sounds good but just missing testpipes. Thanks!
Old Feb 22, 2017 | 09:01 PM
  #252
Nuke's Avatar
Nuke
Here you go,
https://www.vividracing.com/catalog/...151451359.html
Old Feb 22, 2017 | 11:17 PM
  #253
LexSense's Avatar
LexSense
350 here...
I've had vrtuned auto flashing module thing in the past... I guess it's been rebranded to something else now something gearbox tuning for the is350.
Go figure there... I've had mixed feelings about vrtuned in general, and whether everything I thought I felt was a placebo.
Can't speak for their piggyback system, but if it was anything like their auto flash I'd be wary of it.
+1 OrangeVirus Tuning (ovtuned) is doing some great things and I've been more than satisfied with their work and customer experience.
They do get pretty busy at times, so expect some delay in their response, but Mathew goes through leaps and bounds to make everything right.
My email threads spans over 100 exchanges with them, and they've been nothing but understanding and willing to answer questions, and boy have I asked a ton of questions lol. They have an is200t tune, so check them out and bounce some questions off of them.
Old Feb 22, 2017 | 11:22 PM
  #254
MasonGrey's Avatar
MasonGrey
I feel like this discussion is turning into piggy back vs. ECU reflash when both have advantages and reasons to choose one over the other.
Building off of what LexSense has stated, I intend to continue working with OVTuned/Delicious on developing an ECU reflash as even this alpha re-flash has been a ton of joy. Just hoping Mat and Bill have time made progress with finding all the tables.
Old Feb 22, 2017 | 11:42 PM
  #255
Nuke's Avatar
Nuke
Frankly speaking I don't care which one comes on the top, all I care about is getting more power out of my car because I love all aspects of my 200t except the power....so you get the idea but my advise to everyone is to wait and see how things turn out
And from my experience with my previous car (Evo X) ECU tuning is always the TOP when it comes to releasing maximum potential of any car
