Shift Solenoid C number?
Old Mar 30, 2014 | 12:13 PM
VIP161's Avatar
VIP161
Default Shift Solenoid C number?
I just came up on some mixed information. I need clarification. On the A650E auto transmission for the GS300, what number solenoid is solenoid C?
Research results show it is number 2. A repair diagram shows me it's number 3. These things are pricey so I want to get it right the first time.
Old Mar 30, 2014 | 08:52 PM
Mandogs300's Avatar
Mandogs300
What problems are you having?
Old Mar 30, 2014 | 09:12 PM
VIP161's Avatar
VIP161
I pulled a soft CEL for the code that pertains to a bad shift solenoid "C". The car drives legit. I just replacing it as soon as I can before it leaves me stranded. The only issue now is identifying solenoid C. Search results showed it being solenoid No. 2 but a repair diagram I found shows that it is No.3.
Old Mar 30, 2014 | 11:03 PM
clos430's Avatar
clos430
Not sure what you mean by "C" but check this out.
http://celsiorup.com/cgi/ita/file/1346923353.pdf
What DTC are you getting ?
Old Mar 31, 2014 | 03:40 PM
VIP161's Avatar
VIP161
P0763 is the code. The scanner reads "shift solenoid C electrical"
Old Mar 31, 2014 | 04:20 PM
clos430's Avatar
clos430
Dtc P0763 is usually a malfunction with the S3 solenoid. If the trans fluid and level are good chances are that solenoid is going bad. I'm pretty sure if you do a search on that dtc you would get all the info you need.
Old Apr 1, 2014 | 12:16 PM
VIP161's Avatar
VIP161
A few searches I've done yielded those results. That is what compelled me to create this for thread, for clarification. I already bought a No.2. I'm going to do the job myself this weekend if I get some free time. I'll be using a multimeter to identify to offending unit.
Old Apr 1, 2014 | 12:27 PM
VIP161's Avatar
VIP161
The tranny was flushed and filled about 6 months ago as well.
Old Apr 1, 2014 | 12:45 PM
VIP161's Avatar
VIP161
https://www.clublexus.com/forums/showthread.php?t=378842&styleid=15
I this link above was one of a few that had me a little confused.
Old Apr 2, 2014 | 08:41 PM
Vegas's Avatar
Vegas
https://www.clublexus.com/forums/gs-...oid-fixed.html
Try this page:
http://lexus.sewellparts.com/accesso...2001/4927.html
Old Apr 2, 2014 | 08:47 PM
Vegas's Avatar
Vegas
It is a very straight forward job. Just remember to replace the magnets in the tranny pan after cleaning it before you re-install.
Old Apr 3, 2014 | 10:46 AM
VIP161's Avatar
VIP161
Great info guys! The actual job does look pretty straight forward. I'll tackle this as soon as I can. Thanks again!
Old Apr 4, 2014 | 06:50 AM
aliga's Avatar
aliga
Former Sponsor
i have all the solenoids came off a running car. 100 shipped.
Old Apr 11, 2014 | 12:18 PM
wbmx1981's Avatar
wbmx1981
Search "P0763". You will find this has been discussed. There is a pic, diagram and a DIY.
https://www.clublexus.com/forums/showthread.php?t=399802&styleid=15
KevinLex11
Oct 5, 2025 12:51 AM
GrayES300
16
Apr 13, 2020 03:15 PM
Cthibodeau
Mar 25, 2019 09:37 PM
KevinLex11
Sep 26, 2018 02:48 AM
Advil4u
Aug 31, 2013 10:46 PM
