intake for 2000 gs300
Old Mar 17, 2014 | 08:00 PM
bran4f33r's Avatar
bran4f33r
Default intake for 2000 gs300
I connected my weapon r intake and when I start my car the engine is bucking ??
Old Mar 17, 2014 | 08:15 PM
bran4f33r's Avatar
bran4f33r
I installed a weapon r secret intake and idk wht I did wrong but when I turn it on my engine keeps bucking lmk asap
Old Mar 17, 2014 | 09:11 PM
offbad's Avatar
offbad
what is bucking?
Old Mar 17, 2014 | 10:18 PM
Kuleaze's Avatar
Kuleaze
Sounds like a sensor isn't feeding the computer the correct information...
Old Mar 18, 2014 | 12:23 AM
XxGoKoUxX's Avatar
XxGoKoUxX
You're in the wrong sectioned forum. This is the 3GS forums
Old Mar 18, 2014 | 07:38 AM
vipXjunky's Avatar
vipXjunky
This is what you do after you hook up the intake. Unplug your battery terminals (both positive and neg) for 30min-1hour, Clean the maf sensor and inside of the throttle body (just where the open is located) and then after you do all of that, put every thing back together and give it another rub, that baby should turn without a problem. (From my experience when I had the same intake)
Old Mar 18, 2014 | 08:22 AM
bran4f33r's Avatar
bran4f33r
thanks im going to try that today and let guys know becasue im prettty sure its the MAF senor. thanks alolt though
Old Mar 18, 2014 | 09:26 PM
bran4f33r's Avatar
bran4f33r
I tried it today abd idk wht the problem is now. What do you mean my give it Another rub? Also I put on the old intake cause I got mad lol and it started up fine no bucking (engine shaking) and it worked then I put back on the weapon r and started bucking again. I ddi realize doe that the intake isnt pulling air unless I press the gas
Old Mar 19, 2014 | 02:30 PM
offbad's Avatar
offbad
did you connect everything correctly?
Old Mar 26, 2014 | 07:02 PM
bran4f33r's Avatar
bran4f33r
yea bro I actually got it fixed but now my car is doing sumtin totally different when I pull off it hesitates to go and when im driving abs I press on the gas it hesitates and I heard back fire from the intake a couple times
itztwinki3
Sep 11, 2014 08:57 PM
NCis300
IS - 1st Gen (2001-2005)
Mar 10, 2012 09:16 PM
Bigwun07
Performance
Feb 26, 2008 07:17 AM
mex lex
Performance
Jan 5, 2007 06:07 AM
PandaAE86
Performance
Oct 13, 2004 12:08 AM
