Finished: Custom AEM EMS V2 Install IS300 - plug n play what?
Old 03-08-15, 11:36 PM
  #31
twojayzed
twojayzed's Avatar
Originally Posted by mitsuguy
Resistors only need removed if you run dual ECU.
I can send you a calibration file if you need one that works with VVTI cam and crank sensors.
That would be a huge help thanks Mitsuguy. I was going to wire the aem in conjunction with my factory ecu, perhaps i'd be better off running it as a full standalone. What seems to be the easier swap in your opinion? There are so many posts surrounding this swap but none that are black and white, some say remove resistor R2 and R4, others say R14 and R16 etc. Giving me a headache.
Old 03-02-16, 12:36 PM
  #32
Krister
Krister's Avatar
Does the wiring also work on an Aristo ECU.. Obviously the pin outs arent the same, but every pin should be more or less there if they are in the IS300 ECU.
Does a 6050 box need to do some internal resistor mods?
Old 03-03-16, 04:07 PM
  #33
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Yes, it will work exactly the same. Some Aristo ECU's have the exact same pinout as the 01 IS also.
Old 03-03-16, 04:08 PM
  #34
mitsuguy
mitsuguy's Avatar
The 6050 can get away with just changing jumpers internally so long as you run separate intake temp and coolant temp sensors.
Old 04-19-16, 05:40 PM
  #35
lxBeef
lxBeef's Avatar
Hey mitsuguy, Very helpful and detailed write up. I am looking to swap a 1JZ-GTE into my 2002 IS300.
Got a question about this your setup in regards to ODB-II emissions. Does your setup trow any CEL codes? I live in an area that requires ODB-II emission. Thanks.
Old 04-19-16, 06:20 PM
  #36
mitsuguy
mitsuguy's Avatar
It is technically possible, but modifications will have to be made to simulate the IGF signal (p1300 defeat), rear o2's will need to be simulated and possibly even fronts.
Old 05-17-16, 09:19 AM
  #37
T51rmkiv
T51rmkiv's Avatar
Any thoughts on running latter model GE ecu with the aristo ecu? I would like the possibility of running the aristo trans with a 2003 GS300 NA-T setup.
Old 04-17-18, 07:54 AM
  #38
braddman
braddman's Avatar
Did anyone ever get the fuel gauge situation working? I just bought a swapped one and it has the same issue.
Old 05-16-18, 04:06 AM
  #39
braddman
braddman's Avatar
Nothing about the fuel gauge? I still have this annoying problem.
Old 10-23-22, 04:18 PM
  #40
kwhipp50
1st Gear
kwhipp50's Avatar
Default jumper/auto
what exactly is changing the jumpers, my plugnplay harness already has iat and ctemp senors plugs ran.
2nd: i wanna keep my auto, what all do i need to wire in with the ecu to keep autmatic?
tryitonce
12-20-11 05:44 PM
Nazar
IS - 1st Gen (2001-2005)
10-12-11 10:16 AM
///M LIFE
Chicago Lexus Club
08-20-03 04:20 PM
Quick Reply: Finished: Custom AEM EMS V2 Install IS300 - plug n play what?
