Is350 engine
Old Jun 3, 2012 | 09:41 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The rear end gearing is close enough not to matter. (4.08 to 3.91). You could keep using the IS250's transmission, which would let you keep using the original driveshaft as well, but ideally you'd use the IS350's transmission, which would require a custom driveshaft or swapping out the rear end (since the driveshafts bolt up differently).
Jeff
Tony52
Feb 7, 2018 01:28 PM
itsivan
Jun 1, 2014 11:30 AM
08lexus350
Build Threads
May 20, 2013 03:20 PM
TangoC
Performance
Jan 9, 2008 01:03 PM
Scotty99
Jan 20, 2006 04:56 PM
