PPE Headers going on Today....
Old May 6, 2011 | 05:28 PM
  #31
Kybball#1's Avatar
Kybball#1
I just want to make sure, is Bank 2 the drivers side?
Old May 6, 2011 | 07:14 PM
  #32
RA072724's Avatar
RA072724
Yes, bank 2 is the drivers side.
Old May 7, 2011 | 09:06 AM
  #33
Kybball#1's Avatar
Kybball#1
Light came back on after about 80 miles this time, same code P0430. Paul sent me a bit longer bung, Hopefully this works, if not, im not sure what to do next.
Old May 7, 2011 | 06:10 PM
  #34
jadeboy's Avatar
jadeboy
O2 simulator from ebay.. that the route I had to take... works to fake signal unless the heater failed in the 02 sensor.
Old May 7, 2011 | 08:37 PM
  #35
Kybball#1's Avatar
Kybball#1
Jade, can you link me up to the simulator you bought?
Old May 8, 2011 | 12:51 PM
  #36
Kybball#1's Avatar
Kybball#1
Ok guys, First threw a 0P430 code, Bank 2... Then Paul from PPE send me a longer bung and i had it welded on Bank 2, now i am throwing a P0420 code, Bank 1, Im assuming that I also need a longer extension for Bank 1 too and hopefully that will fix everything...
Old May 8, 2011 | 05:58 PM
  #37
jadeboy's Avatar
jadeboy
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=270710409207
There is no active auction right now..
But you can message "grassrootnano" on ebay.
Old May 8, 2011 | 08:15 PM
  #38
Kybball#1's Avatar
Kybball#1
Jade, how hard are they to install? and did you buy one for both sides? You said this solved your problem correct?
Old May 8, 2011 | 08:33 PM
  #39
jadeboy's Avatar
jadeboy
It will solve YOUR CEL code.. but my heater for the O2 sensor failed too (different CEL) which the O2 simulator couldn't solved (had to get new O2 sensors and High Flow Cat to solve my problem.. didn't need the O2 simulators now). You will need to buy 2 O2 simulators for the 2 sides.
Installation requires you to tap some power from your vehicle.. I would recommend the O2 simulators as your last solution.. try everything else before you goto to this..
I had a long drama.. with the PPE header at this thread here... It will give you more info
https://www.clublexus.com/forums/per...-is-350-a.html
Old May 8, 2011 | 08:49 PM
  #40
Kybball#1's Avatar
Kybball#1
LIke i stated was a P0430 code, Bank 2, paul sent me a longer extender, now im getting the P0420 code, Bank 1 so im hoping a longer extender on Bank 1 will clear it all up.
Old May 16, 2011 | 10:49 AM
  #41
HERBos's Avatar
HERBos
so are u still getting codes? wat a hassle to get it to work properly...
Old May 17, 2011 | 08:25 PM
  #42
ricanrolla's Avatar
ricanrolla
This is why I haven't ordered yet. Hopefully PPE will come up with a better solution...
Old May 18, 2011 | 09:44 AM
  #43
HERBos's Avatar
HERBos
if PAUL (PPE) is not lying to me i think he already came up with a solution..
Old May 18, 2011 | 08:17 PM
  #44
AZ JB's Avatar
AZ JB
He's not.. They have been using my car for the testing of the solution and the results are promising.
Old May 23, 2011 | 09:14 AM
  #45
HERBos's Avatar
HERBos
yes, just as i thought. thats why im getting mine soon (:
him101
Canada
Jan 12, 2020 06:22 PM
GrantReid
Oct 11, 2017 11:44 AM
uaaction
Performance
Aug 20, 2010 03:44 AM
LEX2K2
Performance
Sep 1, 2004 04:04 AM
