2jgte vvti or non vvti ???????
Ok so for a long time I was not sure if to go na-t or gte finally decided best for the long run in going gte.Now am face with people telling me to put a non vvti motor in my secound gen gs because that will be easier for tunning and am getting the same thing told the other way.Just woundering if anybody could put there 2 sense in it to help me with my disition
Well the car is a 99 but evrybody gives me diffrent opinions so its kind of. Hard to decide I know the vvti is the most plug and play but wired up correctly is the non vvti a better motor on the long run
Honestly I'm too sure. Depends on your goals? You'll find tons of info and hours of reading about that topic on supraforums and clubna-t.
From what I understand the VVTI puts out a little more torque, but u loose the flexibility of in depth timing adjustments because you can't install the adjustable intake cam gear, you only use it on the exhaust cam.
And it takes more work for the person tuning it. Non-vvti supras have been around so long that's what most shops will probably have prior experience with, unless they have done some turbo is300's since they are vvti and as there are lots of those around..
Yea thank you for your input I think even doe my car comes with a vvti motor am going to go with the non vvti motor seems like there will be less trouble with tunning later on
